Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-16-2012, 09:11 PM   #1
Staining bricks that dont match
I am adding a large brick addition to my home. The brick in one area does not match the rest of the brick. My contractor is proposing to stain the brick to match instead of replacing. Does this seem like a reasonable solution? I understand bricks come in different lots, but it seems like they should have made sure they had matching bricks before doing the job.
tidewater is offline   Reply With Quote
Old 05-16-2012, 09:20 PM   #2
No reason the bricks can not be matched close enough no one will notice.
I've never once heard a mason suggest trying to stain them.
If they tryed that you would end up having to stain the whole wall at least to get it to match.
Old 05-16-2012, 11:54 PM   #3
thanks joecaptain. actually the issue is that sections of bricks in the NEW section don't all match with each over. seems to me like this should have been checked before installing the bricks
Old 05-17-2012, 02:35 AM   #4
This is a common problem with certain types of bricks, as different batches of the same type can vary slightly and show up when laid in the wall.
The way round it is for the hod carrier to take bricks from different pallets, rather than working a pallet at a time.
stuart45 is offline   Reply With Quote
The Following User Says Thank You to stuart45 For This Useful Post:
jomama45 (05-17-2012)
Staining to match discolored wood tongue and groove ceiling DIY808 Painting 5 01-03-2012 09:10 AM
Reclaimed Bricks (repointing) soft? davidwarner Building & Construction 11 05-06-2010 10:56 AM
Staining wood putty to match board grammyandpa Painting 3 03-08-2009 03:20 PM
Staining to match ponch37300 Painting 3 02-14-2009 08:36 PM
