Stained Vs. Polished Concrete Floor? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-22-2012, 09:45 AM   #1
Rewards Points: 18
Stained vs. Polished concrete floor?
I am refinishing the floor of the lower level of our 1960 split level home. It is on a slab, and we have removed all flooring down to the slab. We would like to have the concrete remain as the flooring, and are planning to have it either polished or stained - and dyed in both cases.
I would like to know if one might look better in a residential setting, or if this is purely individual opinion?
My understanding is the that in polishing, they use increasingly fine grit grinders, up to 1500 or 3000 grit, then seal.
In staining, the grinding stops at about 50 or 100 grit, and then they use acrylic or wax, with a number of layers of wax. The result is less shiny/industrial, and maybe more rustic - but requires a little more upkeep.
I would appreciate any insights or experiences anyone may have. Thank you!
rumiat is online now   Reply With Quote
Old 06-28-2012, 05:07 PM   #2
Stained/polished
Hope you get an answer soon, we are considering the same thing!
johnny42544 is offline   Reply With Quote
Old 06-28-2012, 07:23 PM   #3
Rewards Points: 3,846
I think you understand the polishing process pretty well,though i've never seen polished concrete in a residential setting,only commercial buildings that i'm aware of,though not to say it is never done.
As to staining,i have never seen the floor ground to any degree,the only process i know of is acid staining,that gives the floor a stone or marble look,then a sealer is applied to give it a polished look.
Canarywood1 is offline   Reply With Quote
Pulling up tile want to change to stained concrete drkauf Flooring 1 03-19-2011 05:57 AM
Replacement concrete garage floor, dowelled into foundation? Niffumdutz Building & Construction 5 02-19-2010 08:31 PM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 04:04 PM
Concrete deck -- rotting floor joists jwill Building & Construction 6 09-05-2007 08:01 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
