Stained Cinder Block - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-26-2013, 05:53 PM   #1
bryanp22's Avatar
Rewards Points: 290
Stained cinder block
I've attached a photo of cinder block that is at the top of my basement wall. I have three blocks that look like this. I believe this is occurring because I have concrete steps on the other side of the wall. The top of the steps are flat though so water may run towards the block when raining . What should I do to fix the issue? I know it has not been caulked in years and ill fix that. Will that be enough or do the steps need to slope away from the house.
bryanp22 is online now   Reply With Quote
Old 03-26-2013, 05:56 PM   #2
bryanp22's Avatar
Rewards Points: 290
Sorry my iphone posted the same message twice so I deleted it. My follow-up question is below.
Old 03-26-2013, 05:59 PM   #3
bryanp22's Avatar
Rewards Points: 290
I am not sure I could add slope to the top of the steps without tearing them out and I did not really want to do that.
Old 03-26-2013, 08:04 PM   #4
Rewards Points: 236
post pic/s of the steps.
Fix'n it is offline   Reply With Quote
Old 03-27-2013, 09:16 AM   #5
Rewards Points: 4,578
you're getting some moisture causing efflorescent salts,,, you can regrade the steps w/stuff from the apron/vest store IF you properly prep the steps,,, use a joint sealant w/backer rod, NEVER caulk,,, we like either polyurethane or 100% silicone tooled per directions
Old 03-28-2013, 07:10 AM   #6
bryanp22's Avatar
Rewards Points: 290
What type of concrete do you use for regrading? Do I have to add rebar or anything where I regreade?
Old 03-28-2013, 07:28 AM   #7
concrete is incorrect mtl,,, regrade w/patching mortar instead,,, BUT properly prep the existing steps AND apply to wet ( no standing wtr - surface saturated dry = won't accept any more wtr ) steps
Old 03-28-2013, 07:41 AM   #8
Mold!! Let's kill it!
Rewards Points: 2,012
Would you explain the difference between joint sealant and caulk?
Old 03-28-2013, 10:28 PM   #9
bryanp22's Avatar
Rewards Points: 290
Here are pictures of the steps. I think to answer the question on caulk. Some people maybe think of caulk as something that shrinks when it dries and is not flexible like acrylic latex instead of say silicone. I just think of it more that its in a tube that I use a caulk gun to apply.
Stained cinder block-image-192206188.jpg   Stained cinder block-image-221581317.jpg
Old 03-29-2013, 06:58 AM   #10
as best i can,,, joint sealants are designed for 2-sid'd adhesion where there is a significant rqmt for expansion/contraction/adhesion/cohesion,,, caulks are generally static in performance
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 07:03 AM
Insulate Top of Cinder block wall HooKooDooKu Building & Construction 0 01-20-2010 10:58 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
