Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-24-2012, 01:00 PM   #1
Stack stone retaining walls for a garden
If I am building several small retaining walls for my garden do I need to mortar them together? I want to use natural stone not block.
kim484 is offline   Reply With Quote
Old 04-24-2012, 01:38 PM   #2
Civil Engineer
We have built at least 50 feet of stone wall in our gardens, no mortar. Most of our town has stone walls, some as tall as 6 feet, virtually none of them mortared. The key to building a solid, dry stacked stone wall is careful selection of the stones so they lock together. And the design is quite different if they are retaining soil versus walls that retain no soil.
Up to about 8 feet tall, the rule of thumb for dry stack stone retaining walls is that the base needs to be a minimum 40 percent as wide as the wall is tall. So a four foot high wall needs to be a minimum 1.6 feet wide at the base. Retaining walls over 4 feet high often require a permit, check with your building inspector.
Building dry stone walls is quite the art, and if you want to use large stones, you need to be pretty strong. Good luck, and enjoy.
decorative stone facade over retaining wall denemante Landscaping & Lawn Care 1 06-25-2011 07:07 AM
Finding a Structural Engineer for retaining walls CplDevilDog Building & Construction 0 05-02-2011 10:44 AM
using faux stone on interior walls...? DIY4EVER Building & Construction 21 12-21-2007 10:43 AM
Retaining Walls tripower Landscaping & Lawn Care 1 09-07-2007 09:57 AM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 01:56 PM
