Stabilize My 100-year-old Concrete Basement Walls - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-11-2012, 02:52 PM   #1
Rewards Points: 55
Stabilize my 100-year-old concrete basement walls
My contractor told me to just chip all the stucco off, but as long as the "stucco" is not crumbling I am going to leave it.
There is one spot that is crumbling more than everywhere else and I would like to know if any of you have dealt with something like this. It is pretty easy to remove the material at the bottom of the walls. Kicking and pulling chips away at it. But if I do not mess with it, it is stable enough.
Is there a product I can spray or brush on the loose surface to add a bit of control? As I said, it is not crumbling on its own, and I would like to figure out if I can just add some surface structure.
jkeuning is offline   Reply With Quote
Old 11-11-2012, 08:28 PM   #2
Rewards Points: 1,220
Make sure of the type of concrete, then you can determine the proper way to repair it. Chances are it is cementious, but it is in the range to not be. Pour some vinegar on it, if it bubbles it is lime based and you will have both a clue to the failure and an indication of the correct fix.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 11-12-2012, 07:11 PM   #3
Rewards Points: 55
Yes bubbles. Thanks!
Old 11-13-2012, 03:27 PM   #4
The cementious stucco that was applied over the lime concrete foundation does not allow the lime concrete to breathe, hence it gets waterlogged and fails. Never apply cementious stucco over lime mortar/concrete/plaster.
Old 11-13-2012, 03:46 PM   #5
Rewards Points: 55
Great news. Thanks. Now I have a winter project.
Once I remove all the stucco, what is the best thing to do to the unfinished walls? Or instead of the "best," what are the top three options? Of course, I can leave them as is, but if there is anything to do to stabilize the material I am interested to know what it is.
Old 11-13-2012, 05:41 PM   #6
Rewards Points: 55
I want to add -
I am not undertaking this project to dry out the basement. I understand that water and moisture need to be controlled from the outside. I also understand that sealing from the inside can create more problems (much like I am facing here!)
I am not undertaking this project to improve the appearance of the lime concrete foundation. Any work that I do in that regard will be undertaken AFTER I have stabilized the crumbling. I imagine that I might put up a stud and drywall wall a few inches in from the foundation walls. Maybe. That is a long way off.
My goal now is to take out all of the cementious stucco and then best preserve what remains. As I chip away (literally) at the project I will post some pictures.
Old 11-14-2012, 09:55 AM   #7
Lime plaster would both protect it and look good, but there is a learning curve to making and using it.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
Poured Concrete foundation basement walls--paint? Ranger2001 Painting 10 07-25-2012 08:57 PM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 09:39 AM
Insulate basement walls, 1/2 concrete / 1/2 wood frame rovers1973 Building & Construction 1 04-25-2010 06:50 PM
