Spalling Tie Beam - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-30-2012, 09:53 PM   #1
Question
Spalling Tie Beam
My GC has found major spalling effect in my 1940s home in Fort Lauderdale. The load bearing tie beams have lost chunks of concrete exposing the rusted rebar. How is this repairable and should this be an additional cost that should be passed on to me?
stevetheprop is offline   Reply With Quote
Old 04-30-2012, 10:03 PM   #2
Rewards Points: 13,270
If it's your house then who else would be paying for it?
Post some pictures.
stevetheprop (05-01-2012)
Old 05-01-2012, 08:08 PM   #3
Any chance that insurance might pay?
Old 05-01-2012, 08:37 PM   #4
Ravenworks's Avatar
That is not what I would call spalling,it looks like it was rotten and someone hit it,fracturing it finishing it off.
Ravenworks is offline   Reply With Quote
The Following User Says Thank You to Ravenworks For This Useful Post:
Old 05-01-2012, 08:54 PM   #5
can it be repaired?
Old 05-01-2012, 08:58 PM   #6
joed's Avatar
Rewards Points: 11,990
That's not spalling. That is complete failure.
Old 05-01-2012, 09:14 PM   #7
Ravenworks's Avatar
It can be fixed,anything can be fixed but it's going to be expensive, you need to exercise caution because your structure is capable of collapse.
We deal with stuff like this all the time in the salt mines and use epoxy injection/concrete,this is NOT a DIY project.
Old 05-01-2012, 10:35 PM   #8
concretemasonry's Avatar
Rewards Points: 2,578
Probably due to the exposure and the possible salt contamination in the aggregate or water. - I has been common on many structures in the area. You need a professional (not a contractor) to evaluate the condition. - Very common in structures built 50 to 70 years ago in the area.
Dick
concretemasonry is online now   Reply With Quote
Tags
concrete repair , spalling
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
drilling through steel I beam DIYguy2000 Building & Construction 3 11-21-2011 09:39 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 01:08 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 02:07 PM
