Spalling Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-25-2012, 03:40 PM   #1
Rewards Points: 57
Spalling Concrete
Hello,
I am a new home owner and just learned the hard way to not use salt on cement stairs. Even the little white pellets that cost a lot.
When summer comes around and it is time for me to search for a contractor to resurface, what are some important questions that I should ask? I want to make sure I hire somebody who know exactly what to do.
thanks
Mudkicker is offline   Reply With Quote
Old 02-25-2012, 04:17 PM   #2
Rewards Points: 12,876
Here's some reading material for you.
http://www.concretenetwork.com/products-overlays/
Old 02-25-2012, 05:21 PM   #3
Deicing salts do increase the number or freeze/thaw cycles that concrete goes through daily, weekly, and monthly in a season. If the concrete isn't properly designed (4000psi, air-entrainment) to allow the absorbed moisture to expand when it re-freezes, the surface pops, peels, and scales off.
I would recommend finding a trained Elite Crete contractor in your area. They are trained to fix concrete spalling correctly. There is much more to it than just troweling down a repair material.
Here is some information on concrete overlays:
http://www.everything-about-concrete...e-overlay.html
Here is where you can find an Elite Crete Installer:
www.elitecrete.com
Creteexpert is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
