Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-20-2012, 09:02 PM   #1
Smoothing dried Concrete
i recentlly poured a patio and alot of rocks in the concrete had came to the top and now it is dry what can i do to make it smoother
Charlesstrick is offline   Reply With Quote
Old 03-20-2012, 11:33 PM   #2
Moderator
Welcome to the forums!
I'll move you to "Concrete" for better response.
Gary
Clothes taking longer to dry?
Old 03-21-2012, 09:34 AM   #3
Coconut Pete's paella!
CoconutPete's Avatar
I bought this thing called a "rub brick" which i used to "grind" the landing I built for my stairs. Ideally I wouldn't have had to, but it was my first time working w/ concrete so It didn't come out perfect. It's not like sanding a door - there are certain things you just can't fix, but the rub brick does smooth it out a little.
CoconutPete is offline   Reply With Quote
Old 03-21-2012, 09:13 PM   #4
diamond grinder & turbo cup wheel (rent), heavy duty pressure wshr 3,500psi, 4gpm, acid etch, overlay w/polymer modified material,,, next time finish the conc properly & you won't have this problem nothing suitable avail @ apron/vest stores
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 01:32 PM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 10:08 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
possible to remove dried concrete? rosco Tools 24 07-06-2010 04:19 PM
