-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Smoothing dried Concrete (http://www.diychatroom.com/f105/smoothing-dried-concrete-137681/)
Charlesstrick 03-20-2012 09:02 PM
i recentlly poured a patio and alot of rocks in the concrete had came to the top and now it is dry what can i do to make it smoother
Gary in WA 03-20-2012 11:33 PM
Welcome to the forums!
I'll move you to "Concrete" for better response.
Gary
CoconutPete 03-21-2012 09:34 AM
I bought this thing called a "rub brick" which i used to "grind" the landing I built for my stairs. Ideally I wouldn't have had to, but it was my first time working w/ concrete so It didn't come out perfect. It's not like sanding a door - there are certain things you just can't fix, but the rub brick does smooth it out a little.
itsreallyconc 03-21-2012 09:13 PM
diamond grinder & turbo cup wheel (rent), heavy duty pressure wshr 3,500psi, 4gpm, acid etch, overlay w/polymer modified material,,, next time finish the conc properly & you won't have this problem :thumbsup: nothing suitable avail @ apron/vest stores :furious:
