Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-10-2012, 04:19 PM   #1
Slim, open space between stonework above window - fill in or leave?
Hi everyone,
I'm new to this forum and would very much love to get advice from you guys about a situation I'm dealing with that worries me. I've got a stone exterior home and two of the windows are having problems (that may not really be anything to worry about - I hope!) with the stonework separating from the metal above the windows. I'm assuming this is because the metal has warped over the years, or it could be due to water infiltration. I'd like to caulk the space to ensure that cold air and water don't get in over the winter, but I worry about the possibility of making it a bigger issue by doing so. What if the split was caused by water infiltration and sealing the space up would have the effect of making the water go further behind the stonework in other places? That could get serious and expensive. Or, am I worrying over nothing?
Attaching a pic here to show you guys what I'm talking about. Any input wold be greatly appreciated!
Cheers,
Mitch
Slim, open space between stonework above window - fill in or leave?-window-stone.jpg
MontrealMitch is offline   Reply With Quote
Old 10-10-2012, 04:20 PM   #2
For some reason, the image is appearing upside-down here! Are you guys able to make it out?
Old 10-10-2012, 04:56 PM   #3
hard to see the split, but I would silicone the crack.
pwgsx is offline   Reply With Quote
Old 10-10-2012, 05:06 PM   #4
Thanks. The crack is what I'm referring to.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Condensation on fiberglass window frame creamaster General Discussion 11 01-05-2012 08:42 PM
Mud bed half up, will concrete fill in the space? cassandra Flooring 6 03-31-2009 09:25 AM
Insulate concrete flor above open crawl space... JamesEric Building & Construction 12 11-25-2008 09:43 AM
Best way to open up attic space? bpchevyguy Building & Construction 7 07-03-2008 07:19 AM
