Sledgehammer - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-03-2013, 07:07 PM   #1
Rewards Points: 79
Sledgehammer
I need to break up some old asphalt (about 2 inches thick). What size sledgehammer should i get? 8lb? 10lb? Wood or fiberglass handle?
Thanks!!
rpearlberg is offline   Reply With Quote
Old 05-03-2013, 07:29 PM   #2
DIY staff
Rewards Points: 7,174
Get either size--depends more on your build than any thing----
Assault is soft and crumbly---a good pick axe might get the job done faster than a sledge hammer--
It's hard to smash something soft like black top----get both---I like fiberglass for a sledge and wood for a pick--
Old 05-03-2013, 07:30 PM   #3
Rewards Points: 79
Thanks. I bought the 8lb fiberglass (mainly because they were out of the 10lb).
Old 05-03-2013, 07:38 PM   #4
DIY staff
Don't you love spell check----see if you can spot the spell check change above---
Old 05-03-2013, 07:40 PM   #5
Rewards Points: 79
Ha!! "Assault"
Old 05-03-2013, 07:47 PM   #6
Concrete & Masonry
Rewards Points: 568
I thought it was just the Illannoy public education.........
An 8# sledge is plenty. Asphalt/assault tends to be more brittle in colder temps, and far more flexible in warm weather. I think it's much easier to take out, by hand at least, when it's colder............
jomama45 is offline   Reply With Quote
Old 05-03-2013, 07:49 PM   #7
Rewards Points: 79
Thanks! So I should stick with the #8? I guess it's good to have around the house anyway...
Old 05-05-2013, 05:05 AM   #8
Rewards Points: 4,642
we use mattocks for the hand work,,, asphalt's too soft & doesn't respond well to sledges im-n-s-h-f sledges do work better on stone & conc
we agree on something, tho,,, MORE tools around the house ( is a good thing / are a good thing ) [ unfortunately my grammar leaves something be desired so, rather than risk oh'mike's snarky scorn, will leave that line as multiple choce ]
stadry is online now   Reply With Quote
how much does the head of a 5 lbs sledgehammer weigh turtlekiller82 General DIY Discussions 6 09-15-2009 10:05 PM
Can 1 chick demo a sidewalk with sledgehammer Annaliese Building & Construction 25 10-23-2008 03:28 AM
