Slab On Slab To Raise Floor - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-11-2013, 09:39 AM   #16
Haverhill Trade 1965
There is a bonding agent you can paint on just before you pour. Ever try to get concrete off your tools, or the foundation wall, when someone doesn't clean it off right away? Or is the floor painted? I do like those drains at the valleys though.
Duckweather is offline   Reply With Quote
Old 01-12-2013, 08:46 AM   #17
Concrete & Masonry
Rewards Points: 548
You'll be fine with the 2 1/4" concrete as long as the existing slab shows now sigh of movement. We do it all the time, and don't attempt to bond the two together. If you want to tile directly to the concrete though, I would suggest allowing the concrete to cure a few weeks minimum to ensure that the majority of the shrinkage has taken place BEFORE tile is placed over it. You may want to discuss use of admixtures with the contractor as well, as these mixes generally need to be placed wetter which in turn creates the risk of more shrinkage. There's plenty of admixtures to overcome this though, and get it to cure & shrink faster.........
jomama45 is offline   Reply With Quote
Floor Joists Over Concrete Slab scootermcrad Building & Construction 38 01-26-2017 11:50 AM
How do I install insulation to floor joist setting on a concrete slab TimmyP Building & Construction 6 01-25-2011 11:53 AM
Purgo Flooring on top of slab w/ radiant floor heat UpComingBuilder Flooring 1 05-30-2010 02:21 PM
Floor Drain retrofit for Slab on Grade Douger_F Plumbing 3 04-02-2009 11:07 AM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
