Slab Foundation No Footing - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-26-2013, 04:08 PM   #1
Slab foundation no footing
30 yr.old home in Florida most have monolithic slabs..somehow this home got away from inspection? Soil (sand) eroding at some corners and other spots..any advice..
Leo Lessard is offline   Reply With Quote
Old 05-26-2013, 04:27 PM   #2
Rewards Points: 3,426
Why do you say it got away from inspection??
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Leo Lessard (05-26-2013)
Old 05-26-2013, 04:53 PM   #3
There is no footing to this slab..
Old 05-26-2013, 05:14 PM   #4
A floating slab is thickened anywhere a load bearing wall will be and all around the perimiter,so your saying your slab is not done this way??
Old 05-26-2013, 05:17 PM   #5
It has no footing. This is a slab.of concrete..sitting on grade..monolithic slab has a foot 12"to 18"inches below grade..
Old 05-26-2013, 05:19 PM   #6
Correct!!
Old 05-26-2013, 05:23 PM   #7
Old School
Willie T's Avatar
Very common, and perfectly legal here in Florida for many years. We seldon seem to have any trouble with them as sand is one of the absolute best foundational bases you can find..... as long as you keep it from eroding away.
That's what the gravel is for... to direct the water run-off.
BTW, that drawing shows a little less than 8" at the edge.
Willie T
The Following 2 Users Say Thank You to Willie T For This Useful Post:
concretemasonry (05-26-2013), Leo Lessard (05-27-2013)
Old 05-27-2013, 06:59 AM   #8
There is no gravel there is no footing along outside where walls are.(perimeter)
Old 05-27-2013, 07:06 AM   #9
Not even 8"in.as your picture..only 4in.slab to perimeter..
Old 05-27-2013, 09:23 AM   #10
Old School
Willie T's Avatar
Has is caused any problems so far?
Willie T
Old 05-27-2013, 09:44 AM   #11
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,... So pack somemore dirt back into where it belongs, 'n re-grade so the water Stops errodin' it...
The Following User Says Thank You to Bondo For This Useful Post:
Old 05-27-2013, 09:54 AM   #12
Erosion..underside of slab exposed in several areas..this house built 1979-80 ..was under the impression this not to code.Home in Ft.Pierce FL.
Old 05-27-2013, 10:09 AM   #13
Old School
Willie T's Avatar
Say it was not built to code? That was 33 years ago. Water under the bridge. (Kind of like Obama... a mistake of supreme magnitude, but we're stuck now.)
As bondo said, get it re-supported, and keep it from doing anything more.
Willie T
The Following 4 Users Say Thank You to Willie T For This Useful Post:
Bondo (05-29-2013), Leo Lessard (05-27-2013), Windows on Wash (05-27-2013)
Old 05-27-2013, 10:33 AM   #14
Rewards Points: 222
that is a massive understatement !
if it is eroded badly = have it , wth is it called again, where they pump concrete under it.
Fix'n it is offline   Reply With Quote
Old 05-27-2013, 03:49 PM   #15
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
Slab jacked?
I hate signatures.
Mort is online now   Reply With Quote
Replace basement shower drain in foundation slab Paul_in_VT Plumbing 4 01-21-2013 02:47 PM
foundation and footing problems garrett reite Concrete, Stone & Masonry 4 07-11-2012 11:17 AM
Ranch Porch Foundation and Footing VDB Building & Construction 1 06-04-2012 10:10 PM
Foundation and footing cracks willk53 Building & Construction 5 04-22-2011 09:46 PM
Adding foundation under a slab. bob grube Building & Construction 9 02-02-2010 12:08 PM
