-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Slab foundation no footing (http://www.diychatroom.com/f105/slab-foundation-no-footing-180584/)
Leo Lessard 05-26-2013 03:08 PM
30 yr.old home in Florida most have monolithic slabs..somehow this home got away from inspection? Soil (sand) eroding at some corners and other spots..any advice..
Canarywood1 05-26-2013 03:27 PM
Why do you say it got away from inspection??
Leo Lessard 05-26-2013 03:53 PM
There is no footing to this slab..
Canarywood1 05-26-2013 04:14 PM
A floating slab is thickened anywhere a load bearing wall will be and all around the perimiter,so your saying your slab is not done this way??
Leo Lessard 05-26-2013 04:17 PM
It has no footing. This is a slab.of concrete..sitting on grade..monolithic slab has a foot 12"to 18"inches below grade..
Leo Lessard 05-26-2013 04:19 PM
Correct!!
Willie T 05-26-2013 04:23 PM
1 Attachment(s)
Very common, and perfectly legal here in Florida for many years. We seldon seem to have any trouble with them as sand is one of the absolute best foundational bases you can find..... as long as you keep it from eroding away.
That's what the gravel is for... to direct the water run-off.
BTW, that drawing shows a little less than 8" at the edge.
Leo Lessard 05-27-2013 05:59 AM
There is no gravel there is no footing along outside where walls are.(perimeter)
Leo Lessard 05-27-2013 06:06 AM
Not even 8"in.as your picture..only 4in.slab to perimeter..
Willie T 05-27-2013 08:23 AM
Has is caused any problems so far?
Bondo 05-27-2013 08:44 AM
Ayuh,... So pack somemore dirt back into where it belongs, 'n re-grade so the water Stops errodin' it...
Leo Lessard 05-27-2013 08:54 AM
Erosion..underside of slab exposed in several areas..this house built 1979-80 ..was under the impression this not to code.Home in Ft.Pierce FL.
Willie T 05-27-2013 09:09 AM
Say it was not built to code? That was 33 years ago. Water under the bridge. (Kind of like Obama... a mistake of supreme magnitude, but we're stuck now.)
As bondo said, get it re-supported, and keep it from doing anything more.
Fix'n it 05-27-2013 09:33 AM
that is a massive understatement !
if it is eroded badly = have it , wth is it called again, where they pump concrete under it.
Mort 05-27-2013 02:49 PM
Slab jacked?
