Simulated Stone Veneer Possible Claim? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-27-2015, 08:59 AM   #1
Rewards Points: 89
Simulated stone veneer possible claim?
Guys, I had simulated stacked stone put around the foundation of my house three years ago. I've noticed a couple things about it that I don't like and was wondering if I had a valid claim.
First, there appears to be a decent amount of fading. Actually, looks great when its wet. But when it dries out, it just looks faded.
Second, many of the pieces of stone are showing surface cracks in the color. The actual stone isn't cracked...only the color on the surface. See picture.
Thanks,
Chris
poolecw is offline   Reply With Quote
Old 04-27-2015, 09:49 AM   #2
Rewards Points: 616
Who is the manufacturer? Some have good warranties some don't. It doesn't normally fade, but those cracks you seeing were probably there from the beginning, you just didn't notice them.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 04-27-2015, 09:53 AM   #3
Concrete & Masonry
Rewards Points: 2,480
I agree, the spiderwebbing cracks were probably there the whole time.
How far above grade is the product? Many have installation directions that don't recommend installing closer than 2-6" from grade. That could be an issue with any potential warranty claim.......
jomama45 is offline   Reply With Quote
Old 04-28-2015, 04:37 PM   #4
Rewards Points: 89
I'm not sure if the manufacturer but can dig up that info. As for be close to grade, it's installed right down to the ground.
Are there any products that will seal the rock and give it that wet look?
Old 04-28-2015, 04:56 PM   #5
Concrete & Masonry
This is the best product I can think of for what you're looking to do. Perhaps Tscarborough has a better suggestion........
Old 04-29-2015, 08:59 AM   #6
Rewards Points: 616
In your situation (material extending to grade), you will not get any help from the manufacturer, nor should you seal it. It will wick water from the soil, then be trapped under the sealer, causing it and the concrete to fail.
The Following User Says Thank You to Tscarborough For This Useful Post:
stadry (04-29-2015)
What to do where cultured stone veneer meets grass shleppy Landscaping & Lawn Care 5 09-03-2014 06:39 PM
Interior stone veneer fireplace: what should I do at drywall? ScooberJake Concrete, Stone & Masonry 6 04-13-2014 09:38 AM
Stone Veneer (ledgestone) fireplace remodel questions Augy Remodeling 11 09-17-2013 04:57 PM
Homeowner Storm Damage Claim Tips Roofmaster417 Roofing/Siding 0 07-24-2011 09:17 PM
