SIKA - Crack Fix Vs Concrete Fix?? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-12-2013, 03:06 PM   #1
Rewards Points: 45
SIKA - Crack Fix vs Concrete Fix??
I have several cracks in my concrete pool deck I want to seal up. Looks like the Sika brand is well respected. I'm a little confused as to which one to use though; Crack Fix or Concrete Fix?
Looks like the crack fix is more of a two part epoxy system and the Concrete Fix is simply a caulk.
Suggestions on which one to use??
Thanks!!
Dan
dschribs is offline   Reply With Quote
Old 06-12-2013, 06:58 PM   #2
Rewards Points: 3,398
[QUOTE=dschribs;1199987]I have several cracks in my concrete pool deck I want to seal up. Looks like the Sika brand is well respected. I'm a little confused as to which one to use though; Crack Fix or Concrete Fix?
Thanks!!
Dan[/QUOTE
For a permanent fix you would want to use the crack fix.
http://www.newegg.com/Product/Produc...9SIA14R0KF3068
Canarywood1 is offline   Reply With Quote
Concrete Sealer For Home Patio & Sidewalk JasonCA Concrete, Stone & Masonry 1 01-22-2013 03:28 AM
"Beige" Concrete Crack Sealant? jeffb99 Concrete, Stone & Masonry 0 09-17-2012 05:12 PM
Crack in concrete foundation bsmith717 Concrete, Stone & Masonry 10 09-06-2012 08:05 PM
Tiling directly over concrete - crack prevention membrane? crayola110 Tiling, ceramics, marble 7 08-23-2012 04:39 PM
Hairline crack on basment concrete patch job signal Flooring 6 10-05-2010 11:38 AM
