Should I Seal Now Or Wait?? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-28-2013, 12:23 PM   #1
n2omichael's Avatar
Rewards Points: 115
Should I seal now or wait??
Hey guys
I just had a new foundation and basement foundation and floor poured for my cottage which is going to be set on top of and supported by 3 jack posts. Right now the 4 foundation walls
And the floor are exposed. Should I seal the floor now or wait until the jack posts and cottage are located??
Can someone recommend a good sealer? I am in Ontario Canada, the basement will be heated, but, only when I am there, so it will freeze and thaw during the seasons.
Thanks!
Michael
n2omichael is offline   Reply With Quote
Old 07-29-2013, 09:49 AM   #2
Rewards Points: 4,578
seal what & why ? we normally don't seal conc other than exterior waterproofing which should be a MUST ! ! be sure to incl a proper toe drain
Old 07-29-2013, 11:49 AM   #3
n2omichael's Avatar
Rewards Points: 115
Seal the basement floor, I plan on painting it and wasn't sure if there was a sealer/Primer I should apply while everything was open exposed
Old 07-29-2013, 12:07 PM   #4
Concrete will continue to cure and develop new porosity (in the future) that cannot be sealed in the present. In your climate this will continue for easily ten years. The chemical stability of the concrete surface is also a long-term variable, starting with fresh concrete. This will affect not only issues related to porosity but to the chemical adhesion of whatever (if any) product you may choose to apply.
I have no pat answer for you, but many are disappointed with the long-term adhesion of coatings on new concrete. You should have some understanding about this with whomever might supply your paint.
Pro Painter is offline   Reply With Quote
Old 07-29-2013, 12:14 PM   #5
before you do anything, conduct a simple moisture test to be certain there's not moisture coming up THRU the conc,,, this is most commonly prevented by the installation of a vapor barrier under the conc.
there's no paint that's traffic-resistant impo,,, painting conc is never a good choice,,, yet coatings are different & the right material will deliver years of excellent svce.
Old 07-29-2013, 12:16 PM   #6
n2omichael's Avatar
Rewards Points: 115
What coating would you recommend? Providing the moisture test is ok
Old 08-04-2013, 06:12 AM   #7
cleaning out part of the backroom & found a partial 5g can of ' concrete protector ' by consolideck,,, we had used it to seal conc,,, sorry,,, had forgotten all about it,,, great stuff - no financial interest only comes in 5's & 55's tho
Old 08-04-2013, 10:16 AM   #8
n2omichael's Avatar
Rewards Points: 115
Cool will check it out, Thanks!
How to apply caulk to seal water pipe through basement wall goshenplumber General DIY Discussions 4 07-08-2013 08:40 PM
Garage door seal segal Windows and Doors 4 05-25-2013 07:47 AM
Bosch Dishwasher leaking along bottom seal of door mtbdudex Appliances 14 10-13-2012 08:49 AM
About to lose it w/toilet seal schnitz411 Plumbing 11 05-27-2010 06:56 PM
do I need to seal tiles, and if so, when...? rtoni Tiling, ceramics, marble 5 03-26-2010 09:41 PM
