Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-31-2012, 06:43 PM   #1
Should I patch chips wall?
I notice that there are several chips on my basement wall (see attached picture on one of the chipped wall). Their sizes are about 2" x 2" x 1".
Since I will cover then with insulation, do you think I should patch them, or am I wasting time and money in doing so? I am thinking to use Quckrete.
Thanks!
325_man is offline   Reply With Quote
Old 12-31-2012, 07:38 PM   #2
The new wall and insulation should be built so it does not make contact with the foundation.
There has to be over 2000 post on this one subject. Look in the search area at the top right.
Want to seal over it use hydrolic cement.
Old 01-04-2013, 09:48 PM   #3
Guywithskills
They are chips, leave them be..
Guywithskills is offline   Reply With Quote
The Following User Says Thank You to Guywithskills For This Useful Post:
325_man (01-04-2013)
removing wall, can I patch laminate floor to connect 2 laminate floors? tworicks Building & Construction 2 01-21-2012 06:47 PM
Wall mount big screen- drywall patch Mudman Project Showcase 3 03-01-2011 06:46 AM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
How to patch crack on brick wall ? anku Building & Construction 1 07-05-2009 09:30 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
