Should I Even Consider Pouring My Own Patio? - Concrete, Stone & Masonry - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-14-2014, 04:31 PM   #16
Rewards Points: 1,684
Weather plays an important role with concrete jobs and here is how it would be if I attempted it.
Start in the spring, nice temperature. I got a good start but summer is approaching and the temperature is now too hot. Well, as an optimist would say, at least I'm a little past half finished. Wait until fall to complete. I thought I got an early fall start but now according to the National Weather Service we will be getting our first snow storm. Dang it, my wife is on my case and I have two choices. Live with the complaining all winter or leave.
Old 04-14-2014, 05:02 PM   #17
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Originally Posted by jomama45 View Post
Are you considering doing a stamped concrete patio yourself???
Oh heck no. It would be a standard broomed-finish. I know better than to try stamping.
And don't think for a minute that you can use non-air-entrained bagged concrete in a Chicago climate.............
Would be trucked-in in this large of size. But like I said, the scope may be drastically downsized.
hyunelan2 is offline   Reply With Quote
Old 04-14-2014, 07:29 PM   #18
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,390
Originally Posted by SPS-1 View Post
Doing the job over 4 days, how did you handle the joint with the previous day's work? Did you put a 2X across for each section, and then use the joint as a control joint?
Exactly... Just moved my 2x4 form over 5 feet, staked it, and poured between last pour and two end walls.
Yes, those were cold joints, but I had both bar and mesh tying everything together.... and 6 mill poly under it all for moisture control. I think I probably painted on a bonding agent on the edge as I went.... I often do.
I cut 5 foot control joints accross each 20 ft long pour also.
Besides cost efficiencies, (probably did it for 700 verse 2000), there was a technical consideration also. I was very concerned about possible water control and wanted a "perfect slope to one corner"... if I ever needed a sump.
I was worried that even with a couple of finishers, getting that perfect slope in a 20x20 might be difficult. By working in sections, I could control that perfect slope much easier than a "asses and elbows" work environment trying to pour 20x20 in one shot in an enclosed tight basement.
Never needed the sump.... it's been perfectly dry.
Good luck
MTN REMODEL LLC is offline   Reply With Quote
Old 04-15-2014, 04:27 PM   #19
Concrete & Masonry
Rewards Points: 620
If that's the case, you might be able to handle it with someone who has decent experience, as well as a few other untrained hands. You might still consider splitting it into 2 pours though. You could always form a lower ledge for a strip of pavers between the two pours in case they don't match perfectly...........
jomama45 is offline   Reply With Quote
Old 04-15-2014, 04:39 PM   #20
Gymschu's Avatar
Rewards Points: 932
Having worked with a masonry contractor in my younger days, let me just say that in the history of bad ideas, mixing, pouring, and finishing your own concrete with limited experience is #1.
The Following User Says Thank You to Gymschu For This Useful Post:
hyunelan2 (04-15-2014)
Old 04-15-2014, 04:49 PM   #21
Rob
Robpo's Avatar
Rewards Points: 826
I was thinking you could form it with concrete keyway and you wouldn't have to strip it and it would help to keep it from heaving. You would still get the checkerboard look.
Robpo is offline   Reply With Quote
The Following User Says Thank You to Robpo For This Useful Post:
MTN REMODEL LLC (04-15-2014)
Old 04-16-2014, 12:06 AM   #22
Rewards Points: 2,516
Abridged story: we want a large patio off the back of our house, about 550 sqft based on the original design..... "How hard can it be?" - she says
I had a 27 x 21 patio done a few years ago. Thats 567 Sqft for the patio plus another 120 sqft for a walk. Never even crossed my mind to bag it.
Should I even consider pouring my own patio?-100_8459.jpg   Should I even consider pouring my own patio?-100_8431.jpg
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
Gymschu (04-16-2014)
Old 04-16-2014, 05:03 AM   #23
Rob
Robpo's Avatar
Rewards Points: 826
Hammerlane, that is nice I like the way you rounded the corners.
hammerlane (04-16-2014)
Old 04-16-2014, 08:19 AM   #24
landfillwizard's Avatar
Rewards Points: 516
Did you make saw cuts for control joints?
landfillwizard is offline   Reply With Quote
Old 04-16-2014, 10:29 AM   #25
Rewards Points: 626
Originally Posted by MTN REMODEL LLC View Post
I've done 400 sq feet in a basement alone, all from sack concrete (didn't want to pay for a pump truck and a couple of finishers.)
Did it in four mix/pours.... did it over 4 days total, over several weeks,(not counting my prep time.).
Used remesh and rebar to tie everything together.
My son and I got over 200 bags down there over several days... We could get a truck close to an outside exit.
I have my own little 2 bag mixer.
I would just keep mixing, pouring, screeding, finishing and back again.... keeping an unset section in front of me.
I'm a GC, not a concrete pro.... but it can be done if you get organized and are strong enough to handle many 80 bags, and have the time.
This was my own home... and I just did it when I had free time. Each day pouring, probably took 4-5 hours working alone. But I was organized, with concrete sack next to my mixer and wood( or the poured concrete after the first pour) so I could just move my mixer along and dump.
Just kind of repitive work.......
Good luck
Lot of cold seams there. so how did it hold up to cracking when it was all said and done?
Nailbags is offline   Reply With Quote
Old 04-16-2014, 11:22 AM   #26
Well... it has performed excellently..... no moisture... no evident cracking
.... but not necessarily fair to say as everything was working with/for me... because I was on virgin unescavated soil.... our "soil" is decomposed granite.... and I epoxied this lower storage/basement area... and I can see no cracking in the cold or cut relief cuts. (And I see no crack in the epoxy coating, which I think would crack)
And I was rebarred and remeshed together.
I did a third car garage in a very similar manner... and I had the chance to look at years later.... and while my cold joint was flush/level... it had a relief crack. But I tool/round my edges, and it looks just like an intended reliefe joint anyways
Best
Peter.
Old 04-16-2014, 09:01 PM   #27
Homerepairguy's Avatar
Rewards Points: 998
The keyway without the rebar sticking out is exactly how I poured the sidewalk along one side of our house, about 30 years ago. That sidewalk is 40 feet long and 5' 5" wide. Each block was about 5' 5" square. The sidewalk is 3-1/2" thick to accommodate 2x4 form.
Just nailed a tapered strip of wood to the 2x4 form to form the key the width of the sidewalk. The taper made it easy to remove the form.
Thirty years later, the top surface of the sidewalk at each joint is still perfectly aligned like the time the sidewalk was poured. I can verify that the tapered keyway works perfectly to keep the blocks aligned vertically for 30 years.
HomeRepairGuy
Homerepairguy is offline   Reply With Quote
The Following User Says Thank You to Homerepairguy For This Useful Post:
MTN REMODEL LLC (04-16-2014)
Old 04-16-2014, 09:16 PM   #28
HomeRepairGuy
YES,,, ^^^^^As Home Guy says.... if I was on grade with surface soils... put in a key and some bar....
heck.... it is virtually no more work/expense.... although I did not need it in my case, I probably should have spent 20 more minutes and formed in a key as just extra and cheap insurance.
Old 04-16-2014, 10:25 PM   #29
May be hard to see but of course.
Should I even consider pouring my own patio?-100_9140.jpg   Should I even consider pouring my own patio?-100_9273.jpg
Old 04-16-2014, 10:38 PM   #30
Nice and neat/clean
Your edge looks great.... how'd you expose the rock in it.?
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
ront02769 (04-18-2014)
Pouring Patio Slab and Post Footings Question average_male Building & Construction 22 04-04-2016 12:13 PM
Transition from a new pitched patio to an existing level patio barlav Concrete, Stone & Masonry 1 05-03-2013 05:20 AM
Pouring patio newbie cpusl Concrete, Stone & Masonry 3 09-06-2012 07:26 PM
how to transform concrete patio into deck IsabellaS Landscaping & Lawn Care 5 07-04-2012 07:41 PM
Patio Cracked & Sinking silvabul Building & Construction 3 05-04-2011 09:53 AM
