Should Have Bought A Hammer Drill - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-16-2012, 04:26 PM   #1
Rewards Points: 862
Should have bought a hammer drill
Hi;
I've had to drill several small (3/16 max) holes in brick, and has me wishing that when I bought my DeWalt variable speed AC powered drill that I had bought the hammer drill instead.
I was advised in one of these forums about drilling in masonry, but I didn't want to spend the extra $ at the time. It wasn't even that much...
I broke one smaller masonry bit (1/8 I think), but was able to continue using it with the shorter shank. All I was doing was drilling one new hole to put up a new (larger) mailbox.
So, next time I have to do some masonry drilling, I think I'll spring for a slower speed drill with the hammer feature. That way, I won't have two of the same basic tool.
So, when I do, what kind of drill bits to I have to buy? Is there a specification I need to look for to know that a drill bit can handle hammering?
FW
Ultrarunner2017 is offline   Reply With Quote
Old 03-16-2012, 06:57 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 608
Ayuh,.... They're called Masonry bits, 'n have carbide cuttin' edges...
Ya just Can't drill masonry without a hammer drill, 'n masonry bits....
Old 03-16-2012, 08:12 PM   #3
DIY staff
Rewards Points: 7,174
For real occasional use---get a cheap one---I have two throw away hammer drills set up for the two most common sizes that I drill----they were only $35 or $40 each---
A good Bosch or Hilti will cost you a lot--best to rent when you need a big boy.
Bit quality varies---Bosch bits are good---Vermont American are not---
Old 03-16-2012, 08:42 PM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
I spent about two hours trying to drill a hole in concrete with a regular drill. Eventually I gave up and bought a hammer drill. It only took about 30 seconds with the correct tool. What most people don't realize is that a hammer drill does not cut the concrete but it actually chisels it.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
The Following User Says Thank You to Clutchcargo For This Useful Post:
oh'mike (03-16-2012)
Old 03-16-2012, 10:20 PM   #5
Rewards Points: 13,296
I have some big boy tools in my equipmet trailer but for around the house use I have a whole set of Ryobi tools that work just fine.
One of the drills I have is one of these.
http://www.cporyobi.com/factory-reco...-drill-drivers
It can be used as a reguler drill or flick a switch and it's a hammer drill.
It also has two speeds.
It uses the cheapest masonery bits with just straight shafts.
Ryobi batterys also cost about 1/2 as much as any other brands. I've had them far outlast the Dewault batterys I used to use.
Old 03-17-2012, 12:07 AM   #6
Rewards Points: 862
I think I bought the DeWalt variable speed AC powered drill because I wanted just that; an AC powered variable speed drill. It's what I use 90% of the time. But I will get a hammer drill before I try anymore masonry drilling. I would still go corded though.
FW
The Following User Says Thank You to Ultrarunner2017 For This Useful Post:
oh'mike (03-17-2012)
7" Tapcon drill bit wobbles?? ARuby Tools 6 08-17-2011 10:53 AM
Quality Hammer drill? Giles Tools 7 01-26-2011 09:10 AM
Drill: What type to buy? Hurriken Tools 13 09-07-2010 05:00 PM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 04:18 PM
hammer drill vs. drill/driver wombosi Tools 10 05-12-2008 10:40 AM
