Sealing Where Sill Plate Meets Foundation - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-21-2013, 11:46 AM   #1
Sealing where sill plate meets foundation
Hi, Not sure if this is the right section for my question, i apologize if it is not. My ranch home was built in 1954, there is no membrane between the sill plate and the poured foundation. There is cement on the inside where they meet. I'm trying to seal things up and fill those cavities with insulation. I noticed some areas were very drafty and found that the cement is loose and separating, so I would like to pull the old loose stuff out and redo. Is there a specific type of cement I should use? Or are there other methods for doing this? What do you suggest? Thanks for any input!
short1 is offline   Reply With Quote
Old 03-21-2013, 11:51 AM   #2
Rewards Points: 13,270
Suggest posting a picture so we can see what your seeing.
Old 03-21-2013, 11:52 AM   #3
Rewards Points: 626
how about some photos?
Nailbags is offline   Reply With Quote
Old 03-21-2013, 11:58 AM   #4
Rewards Points: 4,534
even w/o pics, this is how we do it,,, clean out all the loose conc & mortar then insert closed cell backer rod into the cavities on top of your insulation,,, seal w/a SEALANT, NOT CAULK ( to save on gas, you can buy all the stuff @ your apron/vest store - masonary section aisle
you could also use foam-in-a-can not to be confused w/hair-in-a-can altho the cann'd foam can be messy compared w/tooled sealants,,, 100% silicone works well, too
Old 03-21-2013, 12:08 PM   #5
I wanted pictures to see why it's falling apart in the first place.
Old 03-21-2013, 12:48 PM   #6
Thanks for the replies! Here are a couple pics as requested. itsreallyconc, a little confused with how you said put it in the cavity on top of the insulation, did you mean foundation? joecaption, it's not really falling apart as much as it is loose, i can grab it and lift it.
Old 03-21-2013, 08:59 PM   #7
Rewards Points: 3,410
Just looks like grout or mortar that was put in as a stop gap for air filtration and it'shrunk.
Canarywood1 is offline   Reply With Quote
Old 03-21-2013, 09:05 PM   #8
Rewards Points: 216
yeah. pull that crap out of there and seal it up. i have bricks in that area, kinda fun (not) getting them out of there.
Fix'n it is offline   Reply With Quote
big gap bwtn foundation and sill plate oldhouse49 Building & Construction 3 10-21-2011 08:19 AM
Exterior wall sill plate not sitting on slab deno085 Building & Construction 16 09-30-2011 08:02 AM
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 09:08 PM
Leaking above windows in basement - sill plate sondraaf Building & Construction 2 02-28-2011 11:33 AM
Replace basement sill plate Bcoleman6 Building & Construction 7 01-15-2011 11:01 PM
