Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-22-2012, 07:25 PM   #1
Sealing a leaky old cement washtub
I have an old cement washtub in my basement. We recently used some drain cleaner to unclog the drain and now I can see erosion of the cement in the sink basin and drips of water leaking through the cement on the underside of the slink. Is there any product I can use to reveal this old tub?
Diydky is offline   Reply With Quote
Old 04-22-2012, 08:20 PM   #2
Super Moderator
Yes,there is--it's Hydroban by Latacrete--$100 a gallon.
It will be cheaper to smack that into chunks and buy a new tub.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (04-22-2012), PaliBob (04-22-2012)
Old 04-22-2012, 09:20 PM   #3
Thread killer
Beat me to it. I was going to suggest the 20lb sledge solution.
Canucker is offline   Reply With Quote
The Following User Says Thank You to Canucker For This Useful Post:
Old 04-22-2012, 09:31 PM   #4
get a sledge hammer ..it time to get rid of that relic long over do
Old 04-23-2012, 12:38 PM   #5
Sledge hammer - sounds like fun. Sealer won't work, eh? Thx.
The Following User Says Thank You to Diydky For This Useful Post:
ben's plumbing (04-23-2012)
Moisture Barrier Behind AND on Top of Cement Board JasonCA Remodeling 0 04-07-2012 02:31 PM
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 3 05-15-2011 02:45 PM
general question on portland cement rtoni Building & Construction 2 07-11-2009 09:32 AM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
