Sealing Interior Basement Walls - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-01-2013, 12:22 PM   #1
What is the best way to water seal concrete interior walls that are underground? Or is there a way since there is always going to be moisture under the ground where the exterior wall would be?
Metro is offline   Reply With Quote
Old 04-01-2013, 02:11 PM   #2
Rewards Points: 626
just some FYI sealing the walls is good. but your just moving the water else were in doing so. you need to make sure that there is a french drain to move it away from your house then seal it up. Laticrete is the best stuff on the market for water sealing. So make sure your french drain is in then seal it.
Nailbags is offline   Reply With Quote
Old 04-01-2013, 04:41 PM   #3
Rewards Points: 4,526
1st determine the source of the moisture - either its transmitted thru poorly seal'd exterior walls OR is condensation from cool walls & warm air in the bsmt,,, tape a 2.0 x 2.0 plastic sq onto the wall & ck in a few days,,, IF there's wtr behind, its exterior,,, wtr drops on top of the plastic, its inside sourc'd,,, remediation method depends on the source !
Sealing crawl space rim joists and walls burnt03 Insulation 3 11-11-2012 11:14 AM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 01:07 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Clean crawlspace cinderblock walls (prep for sealing)? syntax53 Building & Construction 1 07-20-2010 02:12 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
