Sealing Cultured Stone - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-20-2013, 04:11 PM   #1
valcarmo72's Avatar
Sealing cultured stone
I have cultured stone half way up the house. See avatar pic. The stone is very nice but is fading because I have direct sun from noon on until it sets. Gets real real hot...when it rains if it gets wet this dry white powder builds up. I wanted to seal it but many people say they are having problems with the sealing of stone especially with direct sun exposure. Any thoughts?
Don't know?...ask someone...
valcarmo72 is offline   Reply With Quote
Old 02-20-2013, 04:13 PM   #2
valcarmo72's Avatar
Here's a pic of the stone...nice bit its fading every year....if I wet it with the hose it looks new again...
Old 02-20-2013, 05:14 PM   #3
Rewards Points: 4,648
,,, then they're using the wrong sealer - probably bought from an apron/vest store your ' cultured stone ' doesn't mean your stone is proficient in opera, symphony, literature, etc - its really conc & all wtr bas'd color fades somewhat,,, find a solvent-based sealer that's uv-resistant,,, seal it in the am before the sun bakes it too much & it'll sound like you glued on bubble-wrap when you rub your hand across the ' stone '
ps - including your location's a HUGE help to responders when asking for advice
IF you need a product, we've used ' CSS ' from eliteCrete [ no financial interest ] about 15 yrs to seal decorative conc AND real/faux stone,,, due to its hi solids content & also being laced w/methyl-methacrylate, we cut it 1CSS : 1 1/2xylene then apply 2 lite spray coats,,, xylene flashes off in less than an hr so spray on another coat,,, IF you get runs, wipe it off quick,,, it will appear slightly glossy when finished but the shine will fade,,, only 1 caution - you'll need to do this again in a couple years,,, i seal our driveway every other yr,,, should resolve your efflorescence problem, too
stadry is online now   Reply With Quote
Old 02-20-2013, 05:19 PM   #4
valcarmo72's Avatar
Awesome good stuff. Gonna try it soon as it around a steady 60 degrees outside. Thx for the info...we have an Extech distributor near by. I'll try to get some from them. Or do u know where the best place to get it is?...internet maybe...
Old 02-20-2013, 05:20 PM   #5
valcarmo72's Avatar
Got it...CSS elitecrete makes it. I'll find it..
Old 02-20-2013, 05:23 PM   #6
elitecrete.com - you don't need to be a licensed installer to buy CSS
Old 02-20-2013, 05:27 PM   #7
valcarmo72's Avatar
Cool Thx again. How should I apply if. Spray it on...brush...etc. what do u recommend being it isn't an even surface...?
Old 02-20-2013, 05:30 PM   #8
mention'd application in 1st response,,, you will need solvent-resistant sprayer ( viton seals ),,, IF you don't need a good sprayer, rent it,,, SOLO is the best !
Old 02-20-2013, 05:41 PM   #9
valcarmo72's Avatar
Awesome Thx again for the help. Much appreciated.
Cultured Stone fireplace lindyloo Concrete, Stone & Masonry 3 10-31-2012 04:32 PM
Sealing Cultured Stone brainstewn Building & Construction 3 05-15-2011 10:11 AM
J-Weep / Flashing for exterior cultured stone veneer wall. Spud Building & Construction 18 08-31-2009 09:44 PM
Cultured stone issues jdrolls Building & Construction 1 06-14-2009 10:56 PM
