Sealing A Concrete Koe Pond - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-07-2012, 11:45 AM   #1
sealing a concrete koe pond
I have recently taken my plastic liner out of my koe pond and made it concrete. I have purchased cleaner, primer, and a rubber coating, everything I was told to do, I have filled it up three times and it is still leaking (entirely), so I assume it is leaking where the sides and the bottom meet. When I pored the concrete I did the sides first, took the forms off and then did the sides.Sounds like they did not coagulate very well. I have used this coating to seal it but it is about $165.00 a gallon, and I have used 4 gallons. I really do not want to purchase anymore if it is not going to work. Can I use marine paint and how long would it take before It is safe for my koe?
tonykemp is offline   Reply With Quote
Old 06-07-2012, 05:00 PM   #2
Rewards Points: 3,416
Can you repost on what you actually did???,and maybe post a pic.
Canarywood1 is offline   Reply With Quote
Old 06-07-2012, 05:55 PM   #3
DIY staff
Rewards Points: 7,174
Picture would sure help---did you coat the entire surface? Did you use alkali resistant mesh at the seams?
Let us know what the exact product is that you used---
Old 06-07-2012, 09:42 PM   #4
Rewards Points: 13,276
To bad, you could have used Dri-Loc for abot $30.00.
Old 06-09-2012, 09:14 AM   #5
Stay-at-home GC
What product did you use to WP the interior?
Do you have any penetrations through the concrete below the waterline (ie. Bottom Drains, Skimmer entrance?
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Need of some help with concrete driveway & patio? imola ghost Concrete, Stone & Masonry 25 04-05-2012 10:03 AM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
Sealing old concrete floor alliekat Flooring 1 09-14-2010 10:52 AM
concrete Repair and Sealing rosco Building & Construction 10 08-19-2010 06:53 AM
Sealing Concrete J. V. General DIY Discussions 4 10-04-2007 04:19 PM
