Sealing Concrete Cellar Floor - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-31-2013, 12:17 PM   #1
Sealing concrete cellar floor
I have a rather large concrete cellar floor. I'm thinking about sealing it with one of the products advertised for that purpose. My biggest reason is to keep the dust down to a minimum. Can someone recommend a good product for this purpose? Cost is a factor, however I'm willing to pay the money if the product is superior.
I hope that this question isn't too general.
Thanks,
DJ
dwlodyka is offline   Reply With Quote
Old 03-31-2013, 01:28 PM   #2
Rewards Points: 13,282
What's the future plans for that area?
Old 03-31-2013, 02:08 PM   #3
The cellar will remain unfinished. I'll put in several work benches and do woodworking, etc. I don't imagine much more. I'll have a workout area but that doesn't require finishing the cellar. My son in law said that, if I didn't seal the concrete, the cellar floor would always be dusty
DJ
Old 04-01-2013, 07:00 AM   #4
Rewards Points: 4,534
listen to your son in law as he's obviously an expert @ determining why your conc's dusting,,, what'd he say: too much wtr on finishing ? too little super-p ? not enojugh wtr-reducer ? heavy on the wet cure process ? finishing w/steel trowel prior to bleedwtr collection ? the soles of your shoes are too abrasive ? too little ceement in the mix ? too MUCH ceement in the mix ? probably the other guys have more reasons just as relevant, too.
conc sealing's a good idea but cheap sealers aren't,,, nevertheless, if cost's an issue, sweep up the floor well & get some eye-of-newt/ground bat wing stuff from the apron/vest store,,, its really not worth a **** to a pro but suits h/o's well
Old 04-01-2013, 03:28 PM   #5
Rewards Points: 3,418
[QUOTE=dwlodyka;1149587]I have a rather large concrete cellar floor. I'm thinking about sealing it with one of the products advertised for that purpose. My biggest reason is to keep the dust down to a minimum. Can someone recommend a good product for this purpose? Cost is a factor, however I'm willing to pay the money if the product is superior.
Thanks,
As long as you put a penetrating sealer down that's silane or siloxane based you'll be good to go,but whatever you do don't use Thompson's.
Canarywood1 is online now   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Nasty Septic gas smell from concrete floor Muggle Plumbing 2 02-20-2013 10:34 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Creating a flat floor on an angled concrete floor? Magno Building & Construction 1 04-14-2011 06:42 AM
WET concrete wall under TOP floor bathroom window---how to stop? Dyoung Building & Construction 8 02-13-2010 11:14 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
