Sealing A Cement Floor - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-03-2012, 02:38 PM   #1
Sealing a cement floor
Will sealing a cement floor help to eliminate bad basement odor?
NurseNoble is offline   Reply With Quote
Old 06-03-2012, 04:21 PM   #2
Rewards Points: 13,752
The odor is far more likly to be caused from nold.
Scrub the walls down with a mildicide.
Run a dehumidifyer, make sure you have working gutters, slope the grade away from the foundation, no mulch piled up againt the foundation.
Old 06-03-2012, 05:52 PM   #3
Rewards Points: 3,630
NO,you need to find the source of the odor and eliminate it.
Canarywood1 is offline   Reply With Quote
Clogged steel pipe under cement floor dberladyn Plumbing 3 07-06-2011 08:13 AM
floor slopes into room, should I use self leveling cement. porchhen9 Kitchen & Bath Remodeling 1 04-27-2011 08:23 PM
Cracked cement floor in garage. gante Building & Construction 9 02-26-2009 11:55 AM
Removing a parkay floor over cement crhoy Flooring 5 01-07-2009 01:42 PM
Uneven\Buldging Cement Basement Floor SSandecki Flooring 5 12-20-2005 05:06 PM
