Seal slate fireplace
I have slate in our front entry way on the floor....I used a stone/concrete sealer from HD....has helf up just fine for the past 10 years....with only 2 initial coats.....
You basically have the choice of 3 different 'shades'....matt, semi-gloss or high gloss....I personally would go matt or semi-gloss....
Note...it will 'deepen' the look....in other words....take a damp rag and wipe your existing slate....that is about how it is going to look...even when dry.
And....welcome to DIY....and pics would be nice....especially before and after....
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
