Seal Joint Between Porch To House - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-30-2012, 11:02 PM   #1
seal joint between porch to house
I am in the planning stages, I have a small front porch with a basement area under it. the current concrete slab has a crack and leaks. I plan to remove the current slab and pour a new slab. I want to make sure I dont have future leaks. I was looking to see if there has been any experience with any mechanical seals embedded into the concrete? One unknown is that there is a steel plate visible from the basement, I cant be sure if it is a L or I beam. with the concrete step on top of it.
These products look interesting. though I don't know if they are availible in a short enough length to make it cost effective.
JP336L is the one I am looking at.
http://www.jpspecialties.com/tpesweets.pdf
Two pictures of the porch stoop.
Outside_View
Inside_View
Thanks,
Mike
mike015pgh is offline   Reply With Quote
Tags
crack , joint , porch , seal
Porch Against House- Anchored or Expansion Joint? Queso Bandit Building & Construction 10 08-25-2011 01:43 PM
Attaching Porch Railing to House Charleston Building & Construction 2 04-22-2011 02:28 PM
Porch has shifted on a house I am considering buying. Need advice ryanclemson Building & Construction 4 01-31-2011 09:30 PM
CBU Joint Issue? cobrakai Kitchen & Bath Remodeling 1 01-19-2011 10:11 PM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 06:42 PM
