Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-25-2012, 12:22 PM   #1
Indentured Servant
Scratch coat for veneer stone
My neighbor and I are discussing a project he is getting underway with this morning. He is putting up some exterior veneer stone and bought a bunch of Quikrete Motar Mix, planning on using this for his scratch coat. I thought he needed a specific type of mix for the coat. Who is correct? The Quikrete web site doesn't say you can't, but it also isn't mentioned as something you can use either.
jackpine is offline   Reply With Quote
Old 08-26-2012, 10:31 AM   #2
Concrete & Masonry
As long as it's the "Type S Mason's Mix", it will be just fine for the scratch coat, and could be used for the adhering of the stones, as well as the grouted joints if you'd like..........
jomama45 is offline   Reply With Quote
Concrete Plaster coat Mix ratio needed, for brick interior wall. Spud Concrete, Stone & Masonry 6 07-08-2012 02:55 PM
Second topcoat blisters over clean skim coat norepeat Painting 8 09-07-2011 07:30 PM
Real Stone Facing Dilemma ydiy Building & Construction 6 06-26-2011 03:07 PM
Scratch Coat Speed3C Flooring 4 06-09-2011 08:58 AM
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 07:57 AM
