Scoring Stained Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-31-2013, 11:09 AM   #1
Scoring stained concrete
We are debating on wether or not to score the floor before staining on a new construction. My question is, if we decide not to score and move forward with the staining, can we score it after it has already been stained, sealed, and finished?
rmayet54 is offline   Reply With Quote
Old 12-31-2013, 03:00 PM   #2
World's Tallest Midget
Mort's Avatar
Rewards Points: 694
If you do it before you stain it, the stain will get in the crack, and the whole thing will be sealed. Afterwards, it won't. I think it'd look better if you scored it first.
I hate signatures.
Mort is offline   Reply With Quote
The Following User Says Thank You to Mort For This Useful Post:
joecaption (12-31-2013)
Old 12-31-2013, 03:05 PM   #3
Concrete & Masonry
Rewards Points: 636
Scoring after is far more likely to scratch the surface as well.......
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Old 01-01-2014, 05:04 AM   #4
Rewards Points: 4,796
yes, of course you can ' score ' after staining,,, even good acid stain's don't usually penetrate usually more than 1/16"-1/8",,, scoring reveals conc's color so you' get a tile effect,,, you can easily score w/1/4" dia blade on 4" grinder - its dusty work ! not sure what else you could use to score as finished conc's fairly hard
we cut prior to sealing,,, solvent-bas'd sealers are MUCH better'n wtr-bas'd,,, don't bother w/anything you find @ apron/vest stores other'n dust masks, brooms, etc - IF you must, try sher-wms - @ least their stuff doesn't suck as much
Tile over previously stained concrete patio. fredm54 Concrete, Stone & Masonry 7 04-16-2013 04:27 AM
Concrete prep for outdoor tile onthejob Concrete, Stone & Masonry 8 03-29-2012 12:34 PM
Polished and Unpolished Concrete Floor Questions pretzels Flooring 5 03-05-2012 03:27 PM
Mulch dye stained concrete. EPERRINGTON Landscaping & Lawn Care 1 04-21-2011 08:57 PM
