Sanding Rough Brick?? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-01-2012, 11:15 AM   #1
My house has this orange rough brick (attached pic) and I figured I should sand it smooth before painting?
What could I use to sand brick smooth?
mjeanfreau is offline   Reply With Quote
Old 04-01-2012, 12:03 PM   #2
Rewards Points: 13,300
I doubt your going to find many fans on trying to do this job.
That would be a huge messy job, and may not even come out right after all that work.
Trying to hold up a heavy grinder all day and hold it flat will be a big undertaking.
And by painting the brick you have taken a next to 0 maintaince wall and made it into high maintaince one.
I know I'd pass on the job no matter how much I needed the money.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
concretemasonry (04-01-2012), PaliBob (04-01-2012)
Old 04-10-2012, 09:46 PM   #3
Rewards Points: 152
Tough one here. Good luck. first post tonight i didnt have an educated answer for.
TRUEPRO is offline   Reply With Quote
Brick veneer is 4 rows below grade- redo or leave? cbrc5eric Building & Construction 11 12-27-2011 09:09 PM
Painting a red brick fireplace with rough brick exterior LoriDebi Painting 1 05-06-2011 12:21 AM
Sanding rough PT deck boards houseinthewoods Painting 2 06-24-2010 07:27 AM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 04:04 PM
