Roughing Up Smooth Conrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-17-2014, 01:18 PM   #1
Rewards Points: 53
Roughing up smooth conrete
I put down a garage door rubber sealer on my concrete so that rain wouldn't leak in. It started coming up in about 3 weeks because the concrete is so smooth. The other garage door has rough concrete and it is fine. What is the easiest way to rough up about a 6 inch wide by 16 foot long section of concrete?
tucker0104 is offline   Reply With Quote
Old 02-17-2014, 01:27 PM   #2
Rewards Points: 13,446
Smooth concrete does not create a water problem.
Lack of a proper 1" step at the threshold or improper grading inside or out is the real issue.
Rough surface just feels less slippery.
May be able to rent a concrete grinder to rough it up.
Any commercial rental place should have one.
Old 02-17-2014, 01:33 PM   #3
Rewards Points: 53
Can I just do it with a sander or angle grinder?
Old 02-17-2014, 02:24 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,006
Ayuh,... A grinder will do it,...
Old 02-17-2014, 06:29 PM   #5
Rewards Points: 53
Any special grit or wheel I should use?
Old 02-18-2014, 08:34 AM   #6
Bondo's Avatar
Ayuh,.... I'd probably just use the carborundum disk that's on my grinder now,...
Imperfect Smooth (Venetian Plaster) peterstb Drywall & Plaster 11 07-21-2013 08:31 PM
What to smooth conrete basement walls with? motopokep General DIY Discussions 0 02-27-2011 11:52 AM
Applying texture on smooth cement interior walls Flt_Simulation Remodeling 8 05-14-2009 05:23 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
how smooth is smooth?? cletus Flooring 2 06-16-2005 04:06 PM
