Rotary Hammers & Dust - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-09-2013, 12:02 PM   #1
Rewards Points: 34
I have a pretty basic question about drilling with a rotary hammer:
I need to drill 3 holes of 1 1/2" diameter through a concrete slab of unknown thickness (likely 6-10") and need to surpress or contain all the dust. Trying to K.I.S.S here so plan is:
Plan A: Shop Vac running with a good filter fitted and hose secured to the floor right at drilling location. If that isn't good enough then
Plan B: Apply water at the bit with a garden sprayer to eliminate dust.
The question is If I wet the bit am I just going to end-up with the bit being locked in place by the water/dust slurry?
Any chance that drilling a small pilot hole would let that stuff drain down & keep the hole clear?
And yes I do have enough drill for this. Bosch 11245evs
midwestcoast is offline   Reply With Quote
Old 04-09-2013, 12:20 PM   #2
Rewards Points: 4,640
UNLESS your brother-in-law's standing there holding a wtr hose on your drill bit, the dust's so fine you'll have dust at your mother-in-law's house diamond coring's best done wet then you can catch the slurry in a wet/dry vac,,, bosch has a dustmuzzle shroud for your drill - look on ebay search dust shroud,
you can also try joedue.com OR dustmuzzle.com,,, all hook up to your vac
plan b would be starting the hole then fitting a 1gal plastic jug over the bit & drill muzzle,,, cut a hole in the jug & stick the suction hose into it
personally, i like using the brother-in-law method best 'cause he'll get filthy &, hopefully, leave sooner to shower
VOLILA ! holes drill'd & the louse is gone
The Following User Says Thank You to stadry For This Useful Post:
midwestcoast (04-09-2013)
Old 04-09-2013, 12:56 PM   #3
Rewards Points: 34
No in-laws involved, but I like the plastic bucket method. Will try that. Thanks
The Dust Deputy and drywall dust JulieMor Tools 3 04-04-2013 07:36 AM
Insulation under staircase...yellow dust?? CanRulez Insulation 0 03-20-2011 08:35 PM
How a saw stand's dust box work Klawman Carpentry 3 12-07-2009 03:19 AM
Sheetrock dust under carpeting in basement... Please help. ben319 Building & Construction 7 09-15-2009 03:35 PM
Use stone dust under bricks to form a border around flower bed Curious123 General DIY Discussions 4 08-23-2009 03:41 PM
