Rock Wall In Shower - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-29-2013, 09:24 AM   #1
Rock Wall in Shower
I am curious to know if a rock wall in a shower needs to be sealed. Before the remodel we used to have it covered by a shower curtain. This used to be an exterior wall. The people before us added the master bed and bath onto the backside of the house. (See attached Pic) If it has to be sealed what would be available, I would like to keep the natural look.
DJohnson521 is offline   Reply With Quote
Old 04-29-2013, 09:43 AM   #2
Rewards Points: 4,534
ALL sealers will add sheen to the rock,,, you just need to determine how much you wish,,, proper sealing will make the shower stall easier to clean,,, find a good sealer from prosoco, sika, or many others ( no $ interest )
Old 04-29-2013, 11:57 AM   #3
Thanks for the reply. I will do some searching to find the best product
Old 04-29-2013, 12:40 PM   #4
Rewards Points: 3,130
We put a stone floor in one of our bathrooms. I sealed it with a product called Aqua Mix Stone Enhancer. No sheen at all, and not expensive. Nothing is going to be permanent - you'll have to redo it periodically. Can't really compare it to other products as it's the only such thing I've ever used.
Old 04-29-2013, 08:53 PM   #5
Rewards Points: 3,426
Using a sealer certainly can't hurt it,the mortar used to construct the wall would surley benifit by using a sealer,and use a penetrating product like one of these in the link.
http://www.nextag.com/siloxane-sealers/products-html
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
jomama45 (04-29-2013)
Old 04-30-2013, 12:18 AM   #6
Rewards Points: 1,232
Most if not all sealers are rated for occasional water. Sealers rated for immersion will generally change the appearance of the surface. If a rock surface is desired for an immersion surface, the backing needs to be rated as a waterproof envelope.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
shower wall stability rtoni Building & Construction 7 01-27-2011 05:11 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Shower Head w/ Hose But Hangs On Wall... Not spout? flipjarg Plumbing 2 02-11-2010 10:19 AM
bathroom shower in basement along foundation wall jeeper Building & Construction 1 04-16-2009 08:20 PM
