Rock And Mortar Stone Foundation/basement Question - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-13-2012, 09:46 AM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 508
Rock and mortar stone foundation/basement question
My friend has a home built in the late 1800s, in the North East. There are some spots with daylight showing. The house was inspected this way when they bought it and they were told it is structurely ok. They are mostly interested in patching these spots so that bugs, rodents, and cold air do not come through too much. Some of the holes are large enough that mice can squeeze through and this may actually be happening. WHat's the best way to seal this up?
this is not theirs, but is very similar.
J187 is offline   Reply With Quote
Old 03-13-2012, 09:58 AM   #2
Civil Engineer
Rewards Points: 4,572
Assuming the house is structurally sound as you state, it should be a relatively simple matter to patch any holes using mortar. If your friends are unfamilar with the process of placing mortar, they can hire a mason to do so, or you can purchase a book on construction of stone walls, which will discuss in detail how to mix, place and finish mortar.
Old 03-13-2012, 02:47 PM   #3
J187's Avatar
Rewards Points: 508
I figured Mortar was an option, but wasn't sure if expanding foam or something else might be better/easier/more efficient... that said, if mortar is the way to go, it shouldn't be a problem at all.
Old 03-14-2012, 12:28 AM   #4
Rewards Points: 4,534
foam has its place but not in a stone foundation wall imo
Old 03-16-2012, 07:52 AM   #5
J187's Avatar
Rewards Points: 508
Thanks for the help. Seems like a pretty quick and easy project.
Old 03-16-2012, 11:24 PM   #6
In a little over my head
Rewards Points: 706
Am I seeing that picture wrong, or is that a rectangular hole for a foundation vent? A few bucks at the local you know where.
ratherbefishing is offline   Reply With Quote
Old 03-16-2012, 11:44 PM   #7
Rewards Points: 13,300
Remove any loose morter first.
Mix up some morter and dump it into a mason bag. It looks like a heavy duty pastery bag. Lowes and HD both have them. Now you will not have it all over the place.
Make sure to clean off any access morter with a wet sponge before it drys.
Old 03-21-2012, 10:58 AM   #8
J187's Avatar
Rewards Points: 508
You certainly are seeing the picture right, but I think perhaps missed that I said the picture above was not the basement in question, rather a similar type of foundation. Thanks though, I do appreciate the suggestion.
Thank you! WIll do.
Also, i'm curious to know what the reasoning is behind avoiding the expanding foam solution.
Old 03-21-2012, 11:13 AM   #9
Rewards Points: 1,232
You should also avoid using portland cement mortar. Do a search on here for "lime mortar".
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Installing a Sterling shower receptor in a mortar base repoocaj Plumbing 2 11-19-2011 08:52 AM
Masonry - river rock to concrete Telkwa Building & Construction 0 08-10-2010 11:50 AM
Repairing concrete mortar siding with exposed crushed rock bridgerunner Building & Construction 2 11-20-2009 08:44 PM
Help! Mortar bed problem! sillyboy22 Flooring 8 10-15-2009 03:59 PM
Replacing slate with stone on a fireplace Debbiesue Building & Construction 4 09-04-2009 05:58 PM
