Ripping Out Asphalt - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-02-2012, 07:17 AM   #1
sweaty
Rewards Points: 276
Ripping Out Asphalt
I need to rip out a section of asphalt about 6 inches wide, 12 inches long, and a few inches deep. How do I rip this out? Would a sledgehammer be able to break it? Do I need a chisel?
sweaty is offline   Reply With Quote
Old 06-02-2012, 07:23 AM   #2
Rewards Points: 13,446
Why such a small area?
I'd make cuts first with a ciruler saw and a masonry blade, cut out the rectangle, then make an X in the middle then the sections should just pop out with a flat bar.
Old 06-02-2012, 07:57 AM   #3
Too Short? Cut it Again!
Grinder or one of the mini-circular saw things with a masonry blade might work better as a circular saw will be too large for, especially, the short ends unless you don't care the cut longer than what you need. Masonry blade may gum up on you though as the friction melts the tar. A cold chisel and hammer should work if you have the patience. Not sure you can contain a sledge hammer to such a small area. I have a Fein multi-tool. Something like it or its cheaper cousins might work nicely if the asphalt is not too deep.
My curiosity matches Joe's. Why such a small cutout?
Old 06-02-2012, 09:09 AM   #4
Rewards Points: 236
what . all that for such a small piece . just dig a place to get your hands under it, and lift it out in 1 piece. should take about 30sec.
Fix'n it is offline   Reply With Quote
Old 06-02-2012, 09:36 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,012
Ayuh,.... My tool of choice would be a Pick-ax...
'bout 2 wacks, 'n it'd be All over...
Bondo is online now   Reply With Quote
Old 06-02-2012, 12:04 PM   #6
sweaty
Rewards Points: 276
I have a downspout extension that is completely clogged. It goes under the asphalt and it is a complete mystery as to where it ends. I'm just going to dig it out, replace it, and leave an opening so the water can actually drain.
Old 06-03-2012, 09:21 AM   #7
Rewards Points: 236
how about some pics ? you have been around long enough to know pics are about mandatory.
Using Recycled Asphalt for Driveway? toddtx Building & Construction 2 07-17-2011 02:24 PM
re: replace asphalt driveway. best method?? gramps416 Building & Construction 12 05-24-2011 11:50 AM
Need advice on 1 1/2 inch of asphalt overlay on concrete and old Asphalt stanlam Off Topic 9 12-05-2010 07:46 PM
Need advice on 1 1/2 inch of asphalt overlay on concret and old Asphalt stanlam Landscaping & Lawn Care 1 11-28-2010 04:50 PM
Asphalt patch/fill/seal with concrete involved brokenknees Building & Construction 1 10-29-2010 02:30 AM
