Retiling The INSIDE Of A Firebox? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-18-2013, 07:54 PM   #1
Retiling the INSIDE of a firebox?
DIYers,
Last year we bought a house from 1911 and the inside of the firebox has (had) approximately 2" square tiles up to the integrated ash-dump. It is all breaking apart, and now I'm not sure what to do.. Is it possible/advisable to try to repair the damage here? Are these a certain sort of special tile that resists heat? What about thinset/mortar?
I read another post on this forum where a DIYer redid a similar situation with Marble tiles, but he didn't seem to use his fireplace for actual fires (we plan to occasionally - heat loss aside).
Can anyone point me in the proper direction here? Any advise? Ideally I think I'd like to find the same tile and just re-do those areas that have crumbled, but we'll be in the house for some time hopefully and would like to do it correctly.
Thank YOU!
javelindesign is offline   Reply With Quote
Old 11-18-2013, 08:22 PM   #2
DIY staff
Rewards Points: 7,174
I'll move this to concrete and masonry for you---that looks like a job or a mason--
Old 11-18-2013, 08:43 PM   #3
Rewards Points: 3,628
There's a lot of different size fire brick out there,and you'll need refractory cement also,this site might be of some help,hope you can find the size you need.
https://www.google.com/search?q=repl...w=1536&bih=718
Canarywood1 is offline   Reply With Quote
Old 11-19-2013, 12:00 PM   #4
Rewards Points: 1,232
You could cut those out of standard red firebrick no problem.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
run spliced lamp cord inside a wall? denemante Electrical 20 12-17-2010 09:35 PM
How much conductor inside J-box? deko Electrical 9 09-08-2010 10:26 PM
AC tripping breaker inside the unit lauratodd HVAC 1 09-01-2010 05:30 PM
Basement moisture - why not seal inside wall? BRO931 Building & Construction 10 08-30-2010 01:47 PM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-05-2005 11:03 PM
