Retaining Wall - Control/Expansion Joint - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-14-2013, 08:44 PM   #1
I'm planning/designing a 8x8x16 CMU retaining wall (2' high retaining + 2.5' high wall beyond retaining grade - no slope). There are 2 separate segments. One segment is 72' long, the other is 52' long with a 90 degree corner at 37'/15'. Location = Phoenix, AZ
Question #1: Local code does not require expansion joints. Does this seem correct? Even though my wall segments are less than 80', is there any advantage of having one of my control joints be an expansion joint?
Question #2: Local code requires control joints every 24'. So, on the 52' segment with 90 degree corner, can I get away with just 1 control joint? If I need to do 2, should I place the 2nd in the shorter 15' section. I know I need to keep control joints 8' from corners, and I'd basically in the middle of the 15' section.
Pbody is offline   Reply With Quote
Old 04-15-2013, 06:12 AM   #2
Rewards Points: 4,454
i wouldn't place an expansion jnt either - not in az,,, control jnts are fine IF needed for code compliance,,, far's distance, ask your inspector,,, if it were me, i would it but i'm far from the last word
Old 04-15-2013, 09:59 AM   #3
Rewards Points: 502
Expansion joints are for clay brickwork; movement joints are for cmu walls which are subject to initial shrinkage.
This is a low (16") and short (25ft) cmu wall which has cracked roughly in the middle. They might have got away without a joint if they'd have used a softer mortar.
Retaining Wall - Control/Expansion Joint-mini-dscf4467.jpg   Retaining Wall - Control/Expansion Joint-mini-dscf4468.jpg
tony.g is offline   Reply With Quote
Please help with retaining wall / patio issue that has arisen. coderguy Landscaping & Lawn Care 3 05-26-2012 05:45 PM
Retaining wall combining concrete blocks and PT lumber JEL Landscaping & Lawn Care 1 04-06-2012 09:39 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 04:29 PM
