Resurface Front Cement Step - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-11-2014, 04:11 PM   #1
Rewards Points: 12
Resurface front cement step
When I purchased this house a few years back there was a crack down the front step. Filled it in and it has held, now my plan is to recoat or resurface it so the patch job I did is not visible and it looks more natural. Not sure where to start as far as what product(s) to use. Is this a job for a cement professional or a fairly easy Do It Yourself project. The rest of the step is just fine, no point in tearing it out to put in a new one. See image for area I am looking to work on. One flat area leading into our house 8 feet by 8 feet.
06Honda is offline   Reply With Quote
Old 04-12-2014, 01:49 AM   #2
Rewards Points: 744
In my opinion, coating it will likely make it look worse. I wouldn't worry about the crack.
Seattle2k is offline   Reply With Quote
The Following User Says Thank You to Seattle2k For This Useful Post:
joecaption (04-12-2014)
Old 04-12-2014, 03:55 PM   #3
Rewards Points: 4,586
don't listen to those guys yes, its fairly simple,,, matter of fact, sher-wms has introduced a product just for that purpose,,, not all stores know about & fewer sher-wms guys are aware of it but its there !
sounds as if your crack is static - if so, the sher-wms stuff should work well for you,,, you can even color it w/their tints
IF you want to see what happens to conc when pro's use a similar product, glom onto concretenetwork.com OR elitecrete.com [ no $ interest but we were licensed eC installers for over 10yrs ]
Old 04-13-2014, 07:01 AM   #4
Rewards Points: 12
Thanks for the info will check that out. I am fine with it as it is but the "wife" has a different eye than me so happy wife happy life.
The Following User Says Thank You to 06Honda For This Useful Post:
Old 04-13-2014, 09:57 AM   #5
Concrete & Masonry
Rewards Points: 548
It looks like there may be silicone over the existing crack as a repair? If that's the case, I don't know of any cementicous patch that's going to stick to it. You'll probably have to remove that first........
jomama45 is offline   Reply With Quote
Old 04-13-2014, 11:26 AM   #6
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,534
I flip alot.... and the concrete is often pretty crappy in walkways etc.
I have had excellent results with Rustoleum's Restore (on concrete... not so fond of it on decking).
I'll patch the cracks/dips up with a vinyl concrete patcher, and then give it a nice consistant/homogenious appearance with Restore.
Put it on carefully and with a very consistant application technique... or else it shows inconsistant brush/roller marks very easily.
I'm sure SW makes a comparable product also.
Restore is now made in what they call 10X which is a thicker/textured application and 4X which is smother. (They apparently now make an Extreem supposedly satisfactory for driveways/tire traffic.
Comes in any color you need... can be tinted appropriately.
Like any surface covering, clean and rough up any slick concreete. If there was silicone on that crack, wire brush it off.
We have pretty heavy weather extreems here, and the stuff has performed great for two plus years for me. (Snow shoveling to sun exposure at 7600 feet altitude)
Good luck
MTN REMODEL LLC is offline   Reply With Quote
Old 04-13-2014, 12:56 PM   #7
Rewards Points: 6,652
This came up on my Facebook feed yesterday for Ardex Concrete dressing. http://www.thisoldhouse.com/toh/how-...353198,00.html Most likely just a bad prep before the pour.
The Following User Says Thank You to gregzoll For This Useful Post:
06Honda (04-23-2014)
Old 04-14-2014, 11:26 PM   #8
Rewards Points: 744
Old 04-14-2014, 11:27 PM   #9
Rewards Points: 744
Actually maybe not http://time.com/24985/happy-wife-hap...er-way-around/
How to Remove Tile Covered Cement step djdenali Concrete, Stone & Masonry 9 02-17-2014 10:15 PM
Home theater riser, step - no step RegeSullivan General DIY Discussions 11 02-08-2014 08:07 AM
Front Door inswing will hit bottom step JStephens11 Building & Construction 12 08-28-2012 10:54 PM
flat cement roof naturallight Roofing/Siding 7 05-11-2012 09:25 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
