Resurface Aggregate Concrete Patio - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-03-2013, 03:36 PM   #1
Rewards Points: 105
resurface aggregate concrete patio
I have a 1980s concrete patio with a very coarse exposed aggregate (3/8" and larger stone). its very painful to walk on and I am curious what my options are.
something similar to this;
can I rent a grinder and go over it or if i need to tear it out and replace it? I also thought about self-leveling in a thin layer overtop but was not sure about durability of that thin layer and its slightly sloped.
any suggestions?
redline9k is offline   Reply With Quote
Old 10-03-2013, 07:49 PM   #2
Rewards Points: 4,538
1980s conc was either exposed aggregate & is still used today altho down here its more common to ' seed ' the conc rather'n use a surface retarder/pressure washer.
a grinder'll certainly do the work IF you want to risk knee/back surgery,,, we use a walk-behind scarifier to ' pop ' the graded pebbles out of the surface then apply a broom'd in base coat of polymer-modified cementitious mtl,,, we then applied another smoothing coat of the same material, ' thinfinish ',,, finally a top coat was installed, finished, & sealed,,, we used elitecrete which is only avail to licensed installers,,, there are also many others avail from specialty conc suppliers,,, you won't find anything worthwhile @ apron/vest stores NOR will you find anyone who knows wth they're doing
o'lays work on conc, not stone,,, no respectable pro would choose self-leveling stuff either
would be a helluva lot less expensive to buy everyone flip-flops
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
Concrete patio blocks the stucco weep screed..how to fix this? westernguy Concrete, Stone & Masonry 0 06-19-2012 05:59 PM
Enclosed porch over existing concrete patio? Pat the Rat Concrete, Stone & Masonry 2 06-10-2012 10:09 PM
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 03:35 PM
Concrete Patio drainage problem lakekids Building & Construction 5 07-17-2008 06:27 AM
