Restoring A Weathered Marble Tabletop - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-11-2012, 09:45 AM   #1
Restoring a Weathered Marble Tabletop
Hi all,
My wife bought a marble and wrought iron bistro table that has been outside, exposed to the elements for years.
The gloss and shine have disappeared from what was once a beautiful table.
Is this a simple case of cleaning with baking soda and water, then using a decent marble sealant, or is there more to it than that?
Thank-you
thomasjw is offline   Reply With Quote
Old 11-11-2012, 09:58 AM   #2
DIY staff
Rewards Points: 7,174
The surface needs to be ground down so it is flat and solid again-----Marble is very soft and easily eaten away by any acid----so the surface becomes porous and uneven---
Sanding with a random orbit sander---moving up in grits as you go---will get you a nice mat finish----if you want a high shine---you will need to use polishing compounds for the last couple of polishings.
A sander will make it look a lot better----try it----
Old 11-12-2012, 10:17 AM   #3
Hey mike,
Thanks for the input. I will hit the tabletop with the orbital sander and go for the polishing compound too.
Would I be accurate in thinking that there is sandpaper specifically for marble that I should be looking for?
What grit should I start and finish with?
Would I be able to find the materials at a Home Depot or Lowe's or should I try and find it at a specialty store?
The tabletop is circular with an ogee edge all the way around, which might be difficult to hit with the orbital sander. Any suggestion there?
Old 11-12-2012, 10:37 AM   #4
Rewards Points: 6,652
Depending on how thick the marble is, you may be better to take it someplace that does stone work, or even gravestones and have them grind the top surface off and polish it back up, then seal the top.
Old 11-12-2012, 11:21 PM   #5
DIY staff
I work marble with regular wood sand paper---good quality--but nothing out of the ordinary---
I make bullnose with a belt sander---polish the edge with an angle grinder----
If you want a factory look---a granite counter top company can get that for you---if you just want it to look like a well loved antique---give the sander a try----as to the bull nose---hand sand--then buff with the grinder---
thomasjw (11-15-2012)
Old 11-15-2012, 07:47 PM   #6
Great advice.
Thank-you Mike.
The Following User Says Thank You to thomasjw For This Useful Post:
oh'mike (11-15-2012)
Tags
marble tabletop , restoration , weathered
Coloring/staining tired marble floor smileibiza Tiling, ceramics, marble 16 12-11-2011 01:12 PM
Adhesive for Marble Threshold Twister Flooring 11 05-14-2011 01:20 PM
marble tile in bathroom floor Arianeg Flooring 1 03-18-2008 03:07 PM
Joining Marble Backsplash to Marble Countertop JLF377 Building & Construction 1 07-29-2007 12:27 PM
