Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-26-2012, 06:58 AM   #1
Repr garage floor crks prior to epoxy/quartz flooring
about to refinish our garage floor w/epoxy(vinyl flake/quartz) in the mix. there are several crks needing repair due to no original contraction jnts. normal trade practice is to diamond -groove them & fill w/epoxy then refinish floor & install epoxy overcoat.
this repair misses the repair goal as cracks will return due to conc liking to be square (stress resistance) IF you ever have the work done, make it a point to full depth diamond saw a proper jnt pattern. yes, there may be some reflective cracking in the overlay however it will NOT be random.
placing backer rod in the sawed jnts will 'control' the expected cracking & result in a much better looking project. we're never had a call-back due to random cracking, delamination along the cracks, or reflective damage
just my thoughts based on 25yrs of this item yes, there's more to this item but i hope most benefit from this thread
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 07:42 PM
Epoxy Garage Flooring boba7523 Flooring 37 02-28-2009 10:24 PM
cheap flooring for portable garage (outdoors) bizgravy Building & Construction 9 11-08-2007 03:23 PM
Flooring a Garage Chuckman Flooring 3 05-29-2006 02:50 AM
