Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-21-2012, 11:03 AM   #1
Repour of a concrete pad over new foam/pex
Hey folks,
So I am having my basement slab torn out within a few days to make way for a radiant floor system.
A few questions....
1. Is there a minimum PSI that I should have the rigid foamboard be? At 4" deep the concrete itself is only... .35 PSI from what I calculated.
2. I plan on using rigid foamboard and taping the seams of each board. Do I still need a 6mil vapor barrier below the foam?
3. Do I need a vapor barrier between the concrete wall and the foamboard (wall)?
4. Is there a particular type of tubing that is best for use in radiant floor systems in slab? I ask because I have a quote for tubing (complete system but I install myself) that is more than triple the price of some I've found on Amazon (still PEX, size, and oxygen resistant)
5. Is there a good supply house that I could buy foamboard and vapor barrier for this application? Seems like the big box stores only carry one type and the prices scare me... I was hoping I could pay less because i'm getting so much (all the walls and the floor).
I'm sure I'll think of more questions.
Thanks guys
Chris
CarlsonRower is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 10:08 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 02:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
