Repointing - Antihyrdo In High Lime Mortar, Freezing - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-10-2012, 12:47 PM   #1
Repointing - Antihyrdo in high lime mortar, Freezing
Is Antihydro product really enough to stop your mortar from freezing? The mortar was N mix with extra lime and sand added to it - so it has some portland cement. It was above freezing until night time the day of repointing. But every day onwards from then on had freezing temps at night and most days, and we didn't have any heaters or blankets on the mortar.
Does Antihydro really make it okay to not wet the bricks before repointing, and not wet the mortar afterwards at all??????
The info on Antihyrdo says it"increases the early and ultimate strength of concrete". Do we have to worry that it made the concrete too hard for old lime mortared brick?
Is the mortar okay if it appears hard, even with concerns that it froze before curing?
THE LAST QUESTIONS I HOPE.
cconsentino is offline   Reply With Quote
Old 12-11-2012, 08:54 AM   #2
Rewards Points: 4,534
when we work'd in the city & metropolitan area (nj-ct-ny-pa), we used it & ever had any trouble
Old 12-11-2012, 11:40 AM   #3
Rewards Points: 1,232
As long as it has initial set (i.e. no free water) before freezing, there is no problem.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 12-11-2012, 04:01 PM   #4
Rewards Points: 3,418
"Is Antihydro product really enough to stop your mortar from freezing?"
The only thing that will keep your mortar or concrete from freezing is heat,there are accelerators out there,that will speed up the set,but they will not keep it from freezing,it's your job to keep it from freezing.
Canarywood1 is offline   Reply With Quote
Stone foundation in barn - add lime or mortar? tbeaulieu Building & Construction 0 06-18-2011 04:28 AM
high side line freezing lilbizzib HVAC 2 06-10-2011 09:54 PM
Venetian Plaster FYI Plaster Ayn Painting 10 07-01-2010 12:26 AM
Chimney repair: rebuild or repoint? cloud9 Building & Construction 33 09-22-2009 10:12 PM
drain freezing from high efficeincy furnance brokenknee Plumbing 4 12-21-2008 09:26 PM
