Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-18-2012, 01:26 PM   #1
Repointing 1930's mortar.
Just wandering what to use and how to match the color. It's too cold now but maybe I could get prepared for spring so I don't waste time researching in the spring. Should I grind out the center with a skinny wheel and chisel the sides?
Or go for it
Should I
Squeakyhinge is offline   Reply With Quote
Old 12-18-2012, 09:01 PM   #2
Go to a real concrete supply house. They should have some sample sticks of morter on a key ring that you can use to match up the color.
If you can pop out a big enough piece just take it with you.
It will look darker when first put on until it drys out.
Just use a 4-1/2" right angle grinder with a diamond blade. It's best to under cut by 1/2 so the morter has something to hold on to.
I mist it down to wash it out and so the brick does not wick out all the moisture in the morter.
Old 12-18-2012, 09:49 PM   #3
Thread killer
Joe's way will work, just a note of caution. If you aren't careful, that diamond blade will go through your brick like a hot knife through butter. Don't ask me how I know. There are attachments for a sawzall that are a little more forgiving
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 12-18-2012, 11:12 PM   #4
Would that be anything like the as170, wow talk about a hot knife through butter, expensive too. Thank you for the direction. I will try the local concrete supply. Places that are usually closed when I'm home from work make me nervous because they seem so interested in just dealing with contractors and such. But I don't know where else I'd go after 4:30.
Old 12-20-2012, 08:44 PM   #5
Mortar from the 30's is most likely a high lime portland mortar. For tuckpointing, aside from the color match, you need to use a soft mortar, especially in a freeze/thaw climate.
Grind the joints to the same thickness of the joint, use a Type N mortar, and make certain to tool the joints.
For matching color, use powdered pigment and make proportional sample batches. Start light and add pigment. Smear the mortar onto a piece of plywood and dry it with a hairdryer, this way you can test samples in seconds.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
Squeakyhinge (12-20-2012)
Old 12-30-2012, 02:32 AM   #6
sorry to jump in, but when i did a little bit, what i did was just mix the the new mortar and pushed it into the gaps.....dont tell me i have to go back and redo it all
federer is offline   Reply With Quote
The Following User Says Thank You to federer For This Useful Post:
Squeakyhinge (12-30-2012)
best mortar for repointing a chimney jared123 Concrete, Stone & Masonry 5 12-19-2012 09:08 AM
Repointing - Antihyrdo in high lime mortar, Freezing cconsentino Concrete, Stone & Masonry 3 12-11-2012 04:01 PM
Mortar Repointing and Dealing With Cracked Bricks Matt Clara Concrete, Stone & Masonry 0 09-30-2012 11:21 PM
More Stone Foundation Repair PAVenturer Building & Construction 11 09-18-2011 08:44 AM
Fieldstone Foundation Trouble - Any "Free Mason" advice available?? dtreger Building & Construction 0 06-29-2011 12:13 PM
