Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-17-2012, 07:24 PM   #1
DJD
Master DIY
DJD's Avatar
Question
Replacing Wood Sill with Limestone.
Hi there, I've removed my 5ft patio door, and eventually will replace it with a vinyl sliding door.
I've removed an old PT door sill. It was tared over brick to attach it to the house. I am pretty sure that was installed wrong.
I've removed the old tar before the picture was taken.
I want to add a limestone door sill, which is pictured. The brick is above the ledger.
Now my question is how do I add the stone in? I was going to add some mortar between the brick and stone, but how to i attach it to the wood joists?
I was planing on shimming the stone on the wood joists to have proper drainage slope, but how would you attach the stone to the wood? I would put blue skin over the wood before the stone also. The stone will have a about 2" of overhang.
Also when the limestone is in, do I need to put a vapour barrier around the stone?
Thanks.
DJD is offline   Reply With Quote
Replacing Sheetrock Window Trim with Wood - NEWB Alert - Please Help! Mark79 Remodeling 7 01-24-2012 12:37 PM
Replacing Wood Floor over 1"x4" in tar underlayment waterlevel Flooring 2 01-16-2012 09:34 PM
Replacing Rotten Band and Sill organick Building & Construction 14 04-13-2011 12:50 PM
Replacing 3-stud Corner and Bottom Sill (56k Beware) TellyDSP Building & Construction 3 03-13-2011 07:28 PM
