-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   Replacing Wood Sill with Limestone. (http://www.diychatroom.com/f105/replacing-wood-sill-limestone-144104/)
DJD 05-17-2012 07:24 PM
Hi there, I've removed my 5ft patio door, and eventually will replace it with a vinyl sliding door.
I've removed an old PT door sill. It was tared over brick to attach it to the house. I am pretty sure that was installed wrong.
I've removed the old tar before the picture was taken.
I want to add a limestone door sill, which is pictured. The brick is above the ledger.
http://img341.imageshack.us/img341/1...0163medium.jpg
http://img35.imageshack.us/img35/998...162mediume.jpg
Now my question is how do I add the stone in? I was going to add some mortar between the brick and stone, but how to i attach it to the wood joists?
I was planing on shimming the stone on the wood joists to have proper drainage slope, but how would you attach the stone to the wood? I would put blue skin over the wood before the stone also. The stone will have a about 2" of overhang.
Also when the limestone is in, do I need to put a vapour barrier around the stone?
Thanks.
