Replacing Water-based Concrete Stain With Acid? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 05-22-2013, 10:59 PM   #1
Question
Replacing water-based concrete stain with acid?
We have 500sf back patio with full sun southern exposure. It was covered in pebble tech which we had demolished & removed, then smoothed over with a grinding machine & cleaned. I was trying to be eco-friendly and stupidly chose a water-based stain instead of acid. I wanted a speckled/mottled/distressed look and the light blue color came on solid, it looked like a swimming pool!!! To add insult to injury, we had a 1970s decorative dolphin which the grinding machine & chemicals couldn't remove. My handyman thought it was ceramic & he didn't know how to remove it (all the other pebble-tech came up easily), so it's still there too .
Within 24 hours we etched it and applied acetone which thinned it out unevenly, and then applied a layer of grey water-based concrete stain on top of that. It looks acceptable but not great, and we haven't sealed it yet. I'm thinking it'll fade, chip over time anyway to get a 'distressed' look??
My question is how hard would it be to do the acid based stain. Any thoughts on putting the acid right on top of the stain to see what happens maybe in a small corner? I do NOT want to have to float a new layer of concrete, nor do I want to grind down again since I'm afraid we've already messed with old concrete a lot and not sure how much more pounding it can handle. The etching & acetone didn't remove it, they only thinned it even with hard scrubbing with tools & steel wool.
What options do we have to 1) leave the water-based stain but give it a 'cool' acid-stain like effect or 2) put an acid on top of a water-based stain or is that nuts??
THANK YOU.
juliesad is offline   Reply With Quote
Old 08-21-2013, 05:51 PM   #2
ask4dan's Avatar
The water-based stain has sealed the concrete to the point that he acid won't do what it is suppose to. I'd almost suggest a faux application of a near slurry mix of the water-based stain using a cushion sponge and a pizza box to get the effect your looking for. Then topcoat it with clear sealer for durability and traffic wear.
ask4dan is offline   Reply With Quote
Old 08-22-2013, 05:15 AM   #3
Rewards Points: 4,752
learn to love the dolphin the issue is depth of penetration,,, wtr-bas'd stains aren't worth a **** im-n-s-h-fo,,, ' pebble-tech ' as a walking surface ? its usually reserved for pool floors/walls,,, i am surprised acetone did anything to a wtr stain as they don't mix/react
best guess is try some acid stain using dan's sponge in the corner as you post'd,,, we used solo sprayers unless it was a big job requiring elec machines,,, dec conc/acid-staining is highly specialized work & i'd guess its required skill/temperment/knowledge is well outside even the best handyman's expertise - just a guess
since wtr-bas'd stains don't change the color of the cement's avail ' free lime ', they aren't real stains as defined by pro's,,, we successfully bail'd out some h/o jobs since wtr-bas'd stains do not, in my experiences, seal conc,,, like using a wtr-bas'd sealer, they're largely useless - again, only my opinion,,, others can/may disagree but i am the world's leading expert on my opinion
good luck !
ps - forgot this part,,, we always used eliteCrete products 'cause if we f'd up, there was a distributor on the other end of the phone who could bail us out,,, most of the trade suppliers just read the directions back to you,,, again, only my opinion based on experiences,,, 1 more point - don't expect great results from sher-wms or the apron/vest stores' products !
stadry is online now   Reply With Quote
Old 08-23-2013, 12:26 PM   #4
K&B Designer
Live_Oak's Avatar
You're at the point of jackhammering it and starting over if you want something substantially different. Water based "stain" is more like paint than stain. It's carp. As you've discovered. Or, depending on how much was removed when you ground it the first time, you might try that route again. But, there should be some wire and rebar in there for reinforcement, and you might not have enough room to do the sanding again without getting into some of that.
Live_Oak is offline   Reply With Quote
Old 08-24-2013, 05:59 PM   #5
Concrete & Masonry
Rewards Points: 620
I hate water-born stains as well, all too common for them to give a monolithic paint look. Acid is far better at mottling/antiquing/variation, BUT you're not going to find a blue tone in acid that will be suitable outside in UV rays (which you already know because this OP is 3 months old.....).
I'm with the old man (itsreallyconcrete) and suggest trying acid in the least conspicuous corner, if you haven't already thrown the towel in. Regardless of the 2 posts saying it wont react, I've had differing actual experiences in the past.........
jomama45 is offline   Reply With Quote
Tags
concrete patio stain , concrete stain , remove water based stain
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Replacing our water heater Lhelson Plumbing 7 07-30-2012 01:09 PM
Is oil based stain dead? CoconutPete Painting 3 07-03-2012 09:52 AM
prep existing concrete floor for acid stain sethco Flooring 3 11-10-2010 07:56 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
