Replacing Small Cracked Porch/Slab (with Pictures) - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-24-2012, 06:59 PM   #1
Replacing Small Cracked Porch/Slab (with pictures)
Hi Everyone,
I've attached a picture of the small cracked porch in front of one of my door entrances. I would like to replace this.
I am not sure why it cracked. Perhaps there is no re-bar or other type material in the porch? Maybe this is why overtime it just cracked?
Besides concrete, what would be the material needed to reinforce the concrete so that this does not happen again?
Anyone have any good resources that I should follow in building a new porch or concrete slab?
How thick should the slab be considering right now it's 42 x 36 inches?
Thanks,
Jason
Replacing Small Cracked Porch/Slab (with pictures)-brokenporch.jpg
JasonCA is offline   Reply With Quote
Old 03-24-2012, 07:31 PM   #2
Rewards Points: 13,960
It most likly failed because the propper prep work was not done under it before poring.
Old 03-24-2012, 08:47 PM   #3
For a slab that small you never really need to use rebar. If I were pouring a slab like that, I would make it at least 4-5 inches deep.
As mentioned by joecaption, the correct prepwork was probably not done. Check out YouTube... there are a lot of very good howtos on pretty much anything you will ever want to do. Here is one that may be helpful:
flipjarg is offline   Reply With Quote
replacing ashphalt with cedar shingles - small roof christy123 Roofing/Siding 12 11-15-2010 07:30 PM
Replacing old BIG potlights with new small ones JanetS Electrical 1 01-30-2010 09:41 AM
Idea for small gap when replacing exterior door Littlerhody Building & Construction 1 04-21-2008 06:40 AM
